Voodoo hyd cam What do you thing, ? NEW PICS. #648167
03/22/10 07:28 PM
03/22/10 07:28 PM
Connecticut, USA
sixty7gtx Offline OP
Connecticut, USA
Voodoo Hyd Cam Kit - Chrysler 361-440 Three Bolt 268/276
Product Description
Hydraulic. The most awesome 268 cam ever produced! Out-powers all others! This High Performance street cam likes 2400 RPM stall, 800 cfm carb, dual plane intake and headers. Makes un-equaled power to 6200 RPM with proper valve springs. Very strong cam with great street manners.
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 226/234
Gross Valve Lift (Int/Exh): .494/.513
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Includes: Cam Kit
Part Number: 60303LK
1967 Plymouth GTX,
1968 HEMI, 4 Spd. Super Bee,
2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648168
03/22/10 07:35 PM
03/22/10 07:35 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Thats a super cam in a mild motor. Makes a ton of power. Big blocks don't need more then 230 duration. Local racer here runs 9.5 at 140 in a 3000 pound car with a 243 duration cam. Motor makes 650 horse on the dyno. Of course the indy heads help. lol
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648169
03/22/10 07:36 PM
03/22/10 07:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what's the rest of the combo, could run good could run like poo poo.
Coming soon!!!!
Re: Voodoo hyd cam What do you thing, ? need help. [Re: Dougsmopars] #648170
03/22/10 07:37 PM
03/22/10 07:37 PM
Connecticut, USA
Connecticut, USA
Ok thanks..
1967 Plymouth GTX,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: Mr.Yuck] #648171
03/22/10 07:39 PM
03/22/10 07:39 PM
Connecticut, USA
Connecticut, USA
edelbrook carb, 2400 stall 2.5 inch pipes. factory exhaust.
1967 Plymouth GTX,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648172
03/22/10 07:47 PM
03/22/10 07:47 PM
Dougsmopars Offline
Dougsmopars  Offline
Use a dual plane intake and check to see if thats an 800 eddy carb. That cam will want more then 650 CFM.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: Dougsmopars] #648173
03/22/10 07:49 PM
03/22/10 07:49 PM
Connecticut, USA
Connecticut, USA
Right now I have a 600, if need be I will change it.
1967 Plymouth GTX,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648174
03/22/10 08:30 PM
03/22/10 08:30 PM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
My brother ran the next cam bigger:
Hydraulic. Hot Street cam, likes 2800 converter, Hi-Rise type dual plane intake with 850cfm carb, headers, 10:1 compression and 3.73 gears. Likes up to 200HP nitrous.
•Advertised Duration (Int/Exh): 276/284
•Duration @ .050 (Int/Exh): 234/242
•Gross Valve Lift (Int/Exh): .513/.533
•LSA/ICL: 110/106
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2200-6400
•Includes: Cam Only
Part Number: 60304
In a mild 440 and it ran really strong! He went to a roller cam and a 500 stroker so I bought it for my 383. These VooDoo cams seem to make good power.
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648175
03/22/10 08:35 PM
03/22/10 08:35 PM
Dougsmopars Offline
Dougsmopars  Offline
The car will make more power with that cam with an 800 or 850 CFM carb. If you stick with Edelbrock get the thunder series carb.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648176
03/22/10 08:50 PM
03/22/10 08:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll say it's not ideal for you then. Not near enough carb, not sure about your intake but a nice dual plane would work. You should have headers, your stall is borderline, a 3000 would work best and 3.91's.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: Dougsmopars] #648177
03/22/10 08:51 PM
03/22/10 08:51 PM
Connecticut, USA
Connecticut, USA
thunder series AVS carb ??
1967 Plymouth GTX,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: Mr.Yuck] #648178
03/22/10 08:53 PM
03/22/10 08:53 PM
Dougsmopars Offline
Dougsmopars  Offline
Converter is fine. All lunarti calls for with that cam is 2400. I have the next cam up and run a 2800 and it's a rocket. But you should get a dual plane intake. Factory HP manifolds will be fine.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: Dougsmopars] #648179
03/23/10 12:41 AM
03/23/10 12:41 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I run the 513 intake 533 exhaust cam in my 470 stroker. It is a PERFECT fit for a street car. I run an 830 Quik Fuel on a Eddy RPM intake on Eddy RPM heads. 2800 converter, 3.91s, 10.4:1 compression. VERY HAPPY with it!!
Best time so far is 11.89 at 113ish mph.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: 67dodge67] #648180
03/23/10 01:33 AM
03/23/10 01:33 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I run the one smaller in a stock 915 head 383 4- speed, 3.23, stock carb intake and exh with 4-hole spacer, few little tricks, Runs super strong !!! tons of low to mid falls off over 5,400rpm but i think thats due to the stock AVS.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648181
03/23/10 01:39 AM
03/23/10 01:39 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run the same cam 60303. It's a good cam however I would highly suggest running headers instead of stock log exhaust manifolds, unless you have hp manifolds. Driveability is perfect, drives around town just like the stock cam did. If I had to do it over again I would go with a higher CR in the 10-11:1 range and step up to the 60305.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: DaytonaTurbo] #648182
03/23/10 06:51 AM
03/23/10 06:51 AM
Connecticut, USA
Connecticut, USA
I want to thank everybody for the input.
1967 Plymouth GTX,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648183
03/23/10 05:50 PM
03/23/10 05:50 PM
Connecticut, USA
Connecticut, USA
totop
1967 Plymouth GTX,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648184
03/29/10 03:05 PM
03/29/10 03:05 PM
Connecticut, USA
Connecticut, USA
specs,
1967 Plymouth GTX,
Re: Voodoo hyd cam What do you thing, ? need help. [Re: sixty7gtx] #648185
03/29/10 05:21 PM
03/29/10 05:21 PM
Dougsmopars Offline
Dougsmopars  Offline
I run the 60304 cam. 513/533. I run a 28 to 3200 stall. Stock HP manifolds with stock 2 1/2 exhaust. Edelbrock performer intake and an 800 thunder series AVS carb. Mopar chrome box. Car runs super. Ton of low end power. I set it in 4 degree's advanced. Cam has excellent street maners.
Re: Voodoo hyd cam What do you thing, ? need help. [Re: Dougsmopars] #648186
03/29/10 05:40 PM
03/29/10 05:40 PM
Connecticut, USA
Connecticut, USA
Sounds like a nice set up.
1967 Plymouth GTX,
