Voodoo hyd cam What do you thing, ? NEW PICS.
#648167
03/22/10 07:28 PM
03/22/10 07:28 PM
Posts: 894 Connecticut, USA
sixty7gtx
Connecticut, USA
Voodoo Hyd Cam Kit - Chrysler 361-440 Three Bolt 268/276 Product Description Hydraulic. The most awesome 268 cam ever produced! Out-powers all others! This High Performance street cam likes 2400 RPM stall, 800 cfm carb, dual plane intake and headers. Makes un-equaled power to 6200 RPM with proper valve springs. Very strong cam with great street manners.
Advertised Duration (Int/Exh): 268/276 Duration @ .050 (Int/Exh): 226/234 Gross Valve Lift (Int/Exh): .494/.513 LSA/ICL: 110/106 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 1800-6200 Includes: Cam Kit
Part Number: 60303LK
1967 Plymouth GTX, 1968 HEMI, 4 Spd. Super Bee, 2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: Voodoo hyd cam What do you thing, ? need help.
[Re: sixty7gtx]
#648174
03/22/10 08:30 PM
03/22/10 08:30 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
My brother ran the next cam bigger:
Hydraulic. Hot Street cam, likes 2800 converter, Hi-Rise type dual plane intake with 850cfm carb, headers, 10:1 compression and 3.73 gears. Likes up to 200HP nitrous.
•Advertised Duration (Int/Exh): 276/284 •Duration @ .050 (Int/Exh): 234/242 •Gross Valve Lift (Int/Exh): .513/.533 •LSA/ICL: 110/106 •Valve Lash (Int/Exh): Hyd/Hyd •RPM Range: 2200-6400 •Includes: Cam Only
Part Number: 60304
In a mild 440 and it ran really strong! He went to a roller cam and a 500 stroker so I bought it for my 383. These VooDoo cams seem to make good power.
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
[Re: sixty7gtx]
#648176
03/22/10 08:50 PM
03/22/10 08:50 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
what's the rest of the combo, could run good could run like poo poo.
edelbrook carb, 2400 stall 2.5 inch pipes. factory exhaust.
I'll say it's not ideal for you then. Not near enough carb, not sure about your intake but a nice dual plane would work. You should have headers, your stall is borderline, a 3000 would work best and 3.91's.
[Re: Dougsmopars]
#648179
03/23/10 12:41 AM
03/23/10 12:41 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Converter is fine. All lunarti calls for with that cam is 2400. I have the next cam up and run a 2800 and it's a rocket. But you should get a dual plane intake. Factory HP manifolds will be fine.
I run the 513 intake 533 exhaust cam in my 470 stroker. It is a PERFECT fit for a street car. I run an 830 Quik Fuel on a Eddy RPM intake on Eddy RPM heads. 2800 converter, 3.91s, 10.4:1 compression. VERY HAPPY with it!!
Best time so far is 11.89 at 113ish mph.
[Re: 67dodge67]
#648180
03/23/10 01:33 AM
03/23/10 01:33 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I run the one smaller in a stock 915 head 383 4- speed, 3.23, stock carb intake and exh with 4-hole spacer, few little tricks, Runs super strong !!! tons of low to mid falls off over 5,400rpm but i think thats due to the stock AVS.
