US Car Tool driveshaft loop-TTI X pipe fit #647957
03/22/10 02:33 PM
03/22/10 02:33 PM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
My car is a '72 Charger-small block, TTI headers with X pipe.
Will a US Car Tool driveshaft loop clear the exhaust in this application?
Neither the exhaust or loop is on yet, I'd rather find out if it's going to fit or not before I put it together.
Re: US Car Tool driveshaft loop-TTI X pipe fit [Re: Stroker] #647958
03/22/10 05:25 PM
03/22/10 05:25 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Sorry all I have
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: US Car Tool driveshaft loop-TTI X pipe fit [Re: HealthServices] #647959
03/22/10 05:38 PM
03/22/10 05:38 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
mine didn't, I had to heat up the s-part that holds the loop. my x pipe is up ALOT tighter than the one posted though
Re: US Car Tool driveshaft loop-TTI X pipe fit [Re: Stroker] #647960
03/22/10 09:15 PM
03/22/10 09:15 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Mine doesn't fit either. I have a TTi 3in X-Pipe, auto transmission. Not a smallblock tho.
Re: US Car Tool driveshaft loop-TTI X pipe fit [Re: Vert] #647961
03/22/10 09:26 PM
03/22/10 09:26 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Has anyone had a d-shaft break-loose with this brand and type loop ? ... With the mounting point way WAY to the front, I would be worried about it keeping the d-shaft contained.
Re: US Car Tool driveshaft loop-TTI X pipe fit [Re: dOc !] #647962
03/22/10 09:30 PM
03/22/10 09:30 PM
Temperance, MI
P
P
Temperance, MI
its NHRA approved, its gotta be safe
Re: US Car Tool driveshaft loop-TTI X pipe fit [Re: prochargedhemi] #647963
03/24/10 09:09 AM
03/24/10 09:09 AM
Stroker Offline OP
Stroker  Offline OP
I guess I'll try the loop after I get the exhaust on.
Sounds like it depends on the car whether it'll fit or not.
I could probably guess better after I get the headers on.
Re: US Car Tool driveshaft loop-TTI X pipe fit [Re: Vert] #647964
03/24/10 12:52 PM
03/24/10 12:52 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I had no luck putting one on my wife's '70 Barracuda. It's running a 440 with Hooker Comp headers & a 3" TTI X-pipe system. As stated in a previous post, the exhaust on her car fits much tighter than the one in the photo above. So tight in fact, that you cannot even see the exhaust in a side-profile shot.
