HEMI Cross Ram Air Cleaners #647847
03/22/10 12:55 PM
03/22/10 12:55 PM
Northern Territory, Australia
Z
Zapp Offline OP
Zapp  Offline OP
Z
I am having my Hemi built ad was wondering if you kind people could post some pics of your Air Filter set-ups. Its going in a Challenge but pics of anything appreciated.
BTW this is not a resto or a Number match car all ideas welcome.
Re: HEMI Cross Ram Air Cleaners [Re: Zapp] #647848
03/22/10 09:41 PM
03/22/10 09:41 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I am watching this one as well!
Re: HEMI Cross Ram Air Cleaners [Re: Lee446] #647849
03/23/10 03:18 AM
03/23/10 03:18 AM
Z
Zapp Offline OP
Zapp  Offline OP
Z
Sadly nothing to see here yet
......anyone???
Re: HEMI Cross Ram Air Cleaners [Re: Zapp] #647850
03/23/10 08:20 AM
03/23/10 08:20 AM
Joplin, Missouri
Mac's Hemi 64 Offline
Joplin, Missouri
What intake and carbs are you using?
Re: HEMI Cross Ram Air Cleaners [Re: Mac's Hemi 64] #647851
03/23/10 09:13 AM
03/23/10 09:13 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
here's what i'm planning on using. i bought this air cleaner at summit racing (pt# sum-g288. i think that's the #. i bought it off of the return table at summit and there wasn't any info with it.). the spacing on the base isn't right when you get it but i was able to open it up to fit the mp crossram with the correct holley carbs. if you can do any fab work at all you can do this also. i haven't ran the car down the road yet so i can't say how well it works at this time. dave
Re: HEMI Cross Ram Air Cleaners [Re: 3ddart] #647852
03/23/10 09:17 AM
03/23/10 09:17 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
from the other side
Re: HEMI Cross Ram Air Cleaners [Re: 3ddart] #647853
03/23/10 09:26 AM
03/23/10 09:26 AM
Chicago
curbman68 Offline
curbman68  Offline
Chicago
This is what I used. A little pricey, but worked well.
Re: HEMI Cross Ram Air Cleaners [Re: curbman68] #647854
03/23/10 09:38 AM
03/23/10 09:38 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Hmmmmmmmmmmmm....................................
Re: HEMI Cross Ram Air Cleaners [Re: RAT PATROL] #647855
03/23/10 07:50 PM
03/23/10 07:50 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have the MP crossram also. I need to measure, but I am thinking of trying to fabricate a base out of aluminum that would let you use the six pack filter and lid,diagonally of course, if that works, take it to Paint it Black and get him to do them in fiberglass for a resonably priced, somewhat factory appearing air cleaner. The other plus would be that the K&N sixpack filters are available in 3" to better match the flow capabilities of the Holleys.
Re: HEMI Cross Ram Air Cleaners [Re: Mac's Hemi 64] #647856
03/23/10 09:10 PM
03/23/10 09:10 PM
Z
Zapp Offline OP
Zapp  Offline OP
Z
My engine is being built at FHO and will have MP Manifold with FHO Billet tops with corrct Holley's, I believe the FHO tops plates still maintain the same Carb placement I will check with Tim.
Re: HEMI Cross Ram Air Cleaners [Re: Zapp] #647857
03/23/10 10:31 PM
03/23/10 10:31 PM
at large
moparphillie Offline
at large
This is the best that I could do given the fact that the NEW Mopar Performance Cross Ram Intake is approx. 1 1/2" taller than the original intakes dating back to 1965. I purchased these ( 2 ) air cleaners from Jegs and had to cut down the bases and then re-weld the bases. They just fit under the factory style 1965 scoop...
Re: HEMI Cross Ram Air Cleaners [Re: moparphillie] #647858
03/24/10 01:49 PM
03/24/10 01:49 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
What is the advantage of the FHO tops? What is different about them than the MP tops? I figured they were just plates to mount the carbs!
Re: HEMI Cross Ram Air Cleaners [Re: Lee446] #647859
03/24/10 06:57 PM
03/24/10 06:57 PM
Z
Zapp Offline OP
Zapp  Offline OP
Z
When I asked if he was using them on my engine he replied "the billet tops are profiled and make quite a bit more power than the Mopar originals" I'll ask Tim for more info if you like
Re: HEMI Cross Ram Air Cleaners [Re: Zapp] #647860
03/24/10 07:25 PM
03/24/10 07:25 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
You bet! I am interested in a set. I looked on their site but did not find them. I wonder how much they are and how much power they are worth?
Re: HEMI Cross Ram Air Cleaners [Re: Lee446] #647861
03/25/10 08:59 AM
03/25/10 08:59 AM
Z
Zapp Offline OP
Zapp  Offline OP
Z
Just in from Tim
"We sell the cross-ram tops for $300 pair. Hp increases depends on total output of the engine. A 500hp engine will see little increase, and one of our NSS 1000hp 604’s will see more than 50hp, as their air flow requirements are quite different. The stock covers tend to warp and leak quite a bit as well, along with being ugly"
Over to you man, call or email Tim he is great to deal with.
Re: HEMI Cross Ram Air Cleaners [Re: Zapp] #647862
03/25/10 11:37 AM
03/25/10 11:37 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Thanks, Zapp.
Re: HEMI Cross Ram Air Cleaners [Re: Lee446] #647863
03/25/10 05:27 PM
03/25/10 05:27 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i run 10.40's with these
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: HEMI Cross Ram Air Cleaners [Re: 68 HEMI GTS] #647864
03/25/10 05:38 PM
03/25/10 05:38 PM
whats so different than these?
Re: HEMI Cross Ram Air Cleaners #647865
03/25/10 08:30 PM
03/25/10 08:30 PM
Z
Zapp Offline OP
Zapp  Offline OP
Z
Flow therefor Power, dont know how it is achieved but assume that all the work is done on the flip side as the flat top gives nothing away.
Re: HEMI Cross Ram Air Cleaners [Re: Zapp] #647866
03/26/10 09:22 AM
03/26/10 09:22 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Guy's, on a related note, I just put my MP crossram on for the first time. With stock type tin valve covers, I like to never got the covers on! I actually had to take the motor mount loose on the passenger side to jack the motor up to clear the shock tower. The plenums overlap the v/c a lot and I can't get all of the top nuts on the v/c's . It will be a PIA to pull the covers for valve adjustments. Any tips ? 68hemi gts, who's covers are you running? They have deep scallops for acces to the v/c nuts. Thanks!
