What is the correct air cleaner for 1967 4bbl #647572
03/21/10 11:50 PM
03/21/10 11:50 PM
SC
V194 Offline OP
V194  Offline OP
SC
Black, Chrome, dual snorkel, no snorkel, pie pan or decal. Photo would be great
That is 383 4bbl for 1967
Thanks for the help.
Re: What is the correct air cleaner for 1967 4bbl [Re: V194] #647573
03/21/10 11:54 PM
03/21/10 11:54 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
What model?
Re: What is the correct air cleaner for 1967 4bbl [Re: moparpollack] #647574
03/22/10 07:19 AM
03/22/10 07:19 AM
SC
V194 Offline OP
V194  Offline OP
SC
Does it make a difference?
I did not know there were that many options but lets say
B body Plymouth.
Re: What is the correct air cleaner for 1967 4bbl [Re: V194] #647575
03/22/10 08:18 PM
03/22/10 08:18 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Re: What is the correct air cleaner for 1967 4bbl [Re: V194] #647576
03/22/10 10:23 PM
03/22/10 10:23 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
B body Plymouth.
Yes, it does make a difference. A 440 GTX uses a different air cleaner than say a 383 Satellite.
Re: What is the correct air cleaner for 1967 4bbl [Re: NicksGarage] #647577
03/22/10 10:38 PM
03/22/10 10:38 PM
SC
V194 Offline OP
V194  Offline OP
SC
I have a 66 parts manual handy hence my asking the board about a 67. I'm showing two lids that are available for a 66 383 4 bbl car. One single snorkel and one dual snorkel. Of course if it was a CA car the lids contained the nipple. Same for B body and C body (If I am reading this right)
I'm looking for a 4 bbl carter 1967 383 C body air cleaner. Is it dual or single?
If I read Nicks site correctly I think its a dual but it is the sheet metal style snorkels. Not like the GTX style.
Right?
Re: What is the correct air cleaner for 1967 4bbl [Re: V194] #647578
03/23/10 12:04 AM
03/23/10 12:04 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
As far as I know, you would need one with round snorkels and the small cone. Or it could possibly have the large unsiclenced version. I don't have reference photos from survivor 383 HP b-bodies. If someone does, I'd be happy to add them to the site.
Re: What is the correct air cleaner for 1967 4bbl [Re: NicksGarage] #647579
03/23/10 12:58 AM
03/23/10 12:58 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
383 and 440 Super Commando's should have the dual snorkel style.
All others would be a single snorkel. '67's should have the flared cylinder style air snorkels (not the tapered ones).
Not all 4-bbl motors were Super Commando's. What is your exact application? (just saying 4-bbl B-Body is not specific enough)
Re: What is the correct air cleaner for 1967 4bbl [Re: V194] #647580
03/23/10 07:18 AM
03/23/10 07:18 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Had a 67 rp23h satellite that IIRC, had 2 round snorkels air cleaner.
Re: What is the correct air cleaner for 1967 4bbl [Re: buildanother] #647581
03/23/10 08:27 AM
03/23/10 08:27 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Reminds me when I worked in the parts dept!
Re: What is the correct air cleaner for 1967 4bbl [Re: earlybee] #647582
03/23/10 10:42 AM
03/23/10 10:42 AM
chicagoland,usa
chicagoland,usa
Need the last eight of the vin. "yes I know you just want an air filter."
Re: What is the correct air cleaner for 1967 4bbl [Re: V194] #647583
03/23/10 11:07 AM
03/23/10 11:07 AM
Tampa, FL
Garranimal Offline
Garranimal  Offline
Tampa, FL
you might find your info here. I didn't look again to see if the answer is there but i suspect it might be.
http://www.nicksgarage.com/aircleaner.htm
I hope it helps.
Re: What is the correct air cleaner for 1967 4bbl [Re: V194] #647584
03/24/10 09:25 AM
03/24/10 09:25 AM
Vermont
440vitamincx Offline
Vermont
My 383 4bbl. came with twin snorkel and black painted with pie plate. I have one for sale if needed.
Re: What is the correct air cleaner for 1967 4bbl [Re: 440vitamincx] #647585
03/24/10 10:03 PM
03/24/10 10:03 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
A '67? What model?
Re: What is the correct air cleaner for 1967 4bbl [Re: NicksGarage] #647586
03/25/10 02:05 AM
03/25/10 02:05 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
I'm surprised no one has actually posted a pic. Here's what I'm using, replacing the single snorkel air cleaner that came on the 350hp 440 in my '67 300.
Note the smaller diameter dimple at the top, apparently that was standard for C-body applications from what I've seen.
Re: What is the correct air cleaner for 1967 4bbl [Re: MowP4rsn] #647587
03/25/10 02:07 PM
03/25/10 02:07 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I believe that is a '68 C-body air cleaner except for 440 TNT.
