steering columb binding duster #647522
03/21/10 10:46 PM
03/21/10 10:46 PM
CT USA
N
Nick Mineau Offline OP
N
CT USA
hi
i have a 76 duster with p/s and the columb binds causing the wheel not to return after a corner. if i lift up ont the steering wheel you can tell that it frees up the columb. any ideas on how to fix it. thanks
Re: steering columb binding duster [Re: Nick Mineau] #647523
03/21/10 10:48 PM
03/21/10 10:48 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You have to be sure if its the column or gear box.
Re: steering columb binding duster [Re: Nick Mineau] #647524
03/21/10 11:06 PM
03/21/10 11:06 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
My 71 chally does the same thing. The inside of the steering column pulls in and out about 3/8ths of an inch. When it is in, it bindes up, when you pull it out it turns smooth. There is a bad bushing or bearing some where, but I am not sure what parts it needs or if you can even still get parts for it. I've been waiting for a used column to pass my path.
DRIVE EM, DONT HIDE EM.
Re: steering columb binding duster [Re: NITROUSN] #647525
03/21/10 11:08 PM
03/21/10 11:08 PM
CT USA
N
N
CT USA
its defently in the columb. 100% shure it is before the gear box.
Re: steering columb binding duster [Re: ledft79] #647526
03/21/10 11:10 PM
03/21/10 11:10 PM
CT USA
N
N
CT USA
thats exactly what mine does. so there are berings in their? i can pull my wheel in/ out 1/4 inch
Re: steering columb binding duster [Re: Nick Mineau] #647527
03/21/10 11:13 PM
03/21/10 11:13 PM
CT USA
N
N
CT USA
i work at advanced auto so if i pull it apart and get some crossed part#'s i'll let you know how to get them. know i gust need tot know how to pull it apart.
Re: steering columb binding duster [Re: Nick Mineau] #647528
03/22/10 11:27 PM
03/22/10 11:27 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
I was going to make sure that I had access to a spair steering column before I rip into mine. That way when I get into it, if I can't get parts, or just can't figure it out, I can get it back on the road right away, with the spair column. I can't be without my wheels. If you do figure out what it takes, I would be interested in the info.
Re: steering columb binding duster [Re: Nick Mineau] #647529
03/23/10 10:02 AM
03/23/10 10:02 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Had that problem before. You may need to adjust the 3 bolt pattern mount that is at the base of the column, and retains it to the floor. If the steering shaft is not centered in it, it will bind. Another possibility, is the bearing at the top of the column. You would have to pull the steering wheel to get down to it. I suspect the adjustment on the column first though.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: steering columb binding duster [Re: Nick Mineau] #647530
04/03/10 10:29 PM
04/03/10 10:29 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
hi
I just fixed mine today. Mine was missing the snap ring that is on the center shaft, under the crush can. That keeps the can held up, and away, from rubbing and binding on the outer column when turning. A 59 cent fix, you cant beat that. Now it steers free and easy, with no binding.
Re: steering columb binding duster [Re: doctor_mopar] #647531
04/04/10 04:42 AM
04/04/10 04:42 AM
IMGTX Offline
IMGTX  Offline
Two votes for this fix.
It's not as serious as it sounds to fix.
