Re: steering columb binding duster
[Re: Nick Mineau]
#647524
03/21/10 11:06 PM
03/21/10 11:06 PM
Posts: 587 minot north dakota
ledft79
minot north dakota
My 71 chally does the same thing. The inside of the steering column pulls in and out about 3/8ths of an inch. When it is in, it bindes up, when you pull it out it turns smooth. There is a bad bushing or bearing some where, but I am not sure what parts it needs or if you can even still get parts for it. I've been waiting for a used column to pass my path.
DRIVE EM, DONT HIDE EM.
[Re: Nick Mineau]
#647528
03/22/10 11:27 PM
03/22/10 11:27 PM
ledft79
minot north dakota
I was going to make sure that I had access to a spair steering column before I rip into mine. That way when I get into it, if I can't get parts, or just can't figure it out, I can get it back on the road right away, with the spair column. I can't be without my wheels. If you do figure out what it takes, I would be interested in the info.
[Re: Nick Mineau]
#647529
03/23/10 10:02 AM
03/23/10 10:02 AM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
Had that problem before. You may need to adjust the 3 bolt pattern mount that is at the base of the column, and retains it to the floor. If the steering shaft is not centered in it, it will bind. Another possibility, is the bearing at the top of the column. You would have to pull the steering wheel to get down to it. I suspect the adjustment on the column first though.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#647531
04/04/10 04:42 AM
04/04/10 04:42 AM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Two votes for this fix.
It's not as serious as it sounds to fix.
