Fiberglass to metal #646592
03/20/10 11:09 PM
03/20/10 11:09 PM
Anonymous OP
Anonymous OP
A question for the body specialists. What is the process of melding a fiberglass hood scoop to a metal hood?
Thanks in advance for any replies.
Superfreak.
Re: Fiberglass to metal [Re: ] #646593
03/20/10 11:22 PM
03/20/10 11:22 PM
Elizabethtown KY
Six Popper Offline
Six Popper  Offline
Elizabethtown KY
Fusor makes a glue for it as I'm sure more companies do. I will research it and get you a specific product. Which ever way you do it glue or another method I would recomend putting down a couple coats of epoxy primer to your prepped hood first that will give whatever substrate you use a good surface to bite to.
http://www.repaintsupply.com/pd_127ez128ez.cfm
Re: Fiberglass to metal [Re: ] #646594
03/21/10 10:36 AM
03/21/10 10:36 AM
Jacksonville Florida
elitecustombody Offline
Superfreak.
don't spend your time or money on anything other than Marine-Tex, this stuff is the best and will not leave a ghost line,will not crack or bubble even on high stress areas, It has proven it's self to me over the years,the only downside, it's expensive and takes about 5-6 hours to setup and cure
any marine supply store carries it,it comes in gray or white, both work with same results
