727 deep sump pan #646264
03/20/10 06:36 PM
03/20/10 06:36 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
does any one know do i need to run a spacer above my filter with a deep sump trans pan
Re: 727 deep sump pan [Re: moparbud] #646265
03/20/10 06:41 PM
03/20/10 06:41 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Yes .... and the thickness of that spacer depends on the depth of the pan. And IF POSSIBLE .. get a cast pan. It is far less prone to leaking ..and it stiffens the case up.
Re: 727 deep sump pan [Re: dOrk !] #646266
03/20/10 07:10 PM
03/20/10 07:10 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
ok thanks thats what i will get
Re: 727 deep sump pan [Re: moparbud] #646267
03/20/10 10:29 PM
03/20/10 10:29 PM
mo
moparbud Offline OP
moparbud  Offline OP
mo
ok i took the deep sump pan off of another trans and it had a spacer. but it had a gasket between the filter and the spacer is that right or should it be between the trans and spacer
Re: 727 deep sump pan [Re: moparbud] #646268
03/20/10 11:05 PM
03/20/10 11:05 PM
Az
Crizila Offline
Crizila  Offline
Az
Mines between the trans and the spacer.
Fastest 300
