440 Source SFI Harmonic Balancer (BB) Experience #646062
03/20/10 01:29 PM
03/20/10 01:29 PM
Wisconsin USA
Albert Lee Offline OP
Wisconsin USA
Does anyone have any experience with subject $135 balancer. Application is a drag race 500 Hp 440(RB) with 727, low 11 second '64 B Body.
Thanks in advance.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: Albert Lee] #646063
03/20/10 01:46 PM
03/20/10 01:46 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Their cranks and rods are OK. But iD SUGGEST TO GET A GOOD damper.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: domingo] #646064
03/20/10 02:55 PM
03/20/10 02:55 PM
Aurora
E
ebodiesonly Offline
ebodiesonly  Offline
E
Aurora
What's the problem with their damper?
1970 Challenger R/T 383
1970 Challenger Convertible 383
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: ebodiesonly] #646065
03/20/10 03:07 PM
03/20/10 03:07 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm using their 18.1 sfi fluid damper. it's been ok but a couple of meetings ago the crank bolt started coming loose. used a big MF ratchet on it & it's staying put but i'm thinking the damper might be out of it's league. i'm running 730ish HP. will upgrade to an ATI over the off season.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: Albert Lee] #646066
03/20/10 05:01 PM
03/20/10 05:01 PM
North Branch, MI, USA
notchbackcuda Offline
We have one of their balancers on a 3100lb 68 Barracuda with a 499 cu in b block (eagle stuff).
car runs 10.24 in the quarter. 4 years no problems.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: notchbackcuda] #646067
03/20/10 05:45 PM
03/20/10 05:45 PM
tboomer Offline
tboomer  Offline
Al...I have a Summit SFI balancer on mine...The same one Vernmotor uses...You have a Summit pro shop discount number?
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: tboomer] #646068
03/20/10 06:03 PM
03/20/10 06:03 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I got ATI now,,the summit one took a poop..
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: VernMotor] #646069
03/20/10 06:39 PM
03/20/10 06:39 PM
tboomer Offline
tboomer  Offline
What happened???
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: tboomer] #646070
03/20/10 06:44 PM
03/20/10 06:44 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Outside ring of it moves.back and fore 4 degs...Makes for a back door- door stop now.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: VernMotor] #646071
03/20/10 07:30 PM
03/20/10 07:30 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If I can't find an ATI used it looks like I'll be using a Profesional Products Dampner.
Scott has used them on a few builds and has not as of yet seen any issues. He did mention that prior to installing you should loctite the bolts that are in it though.
FWIW, I have one of these on the 360 in the 72 and it's been fine. It was on the motor when we got it.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: WILD BILL] #646072
03/20/10 10:08 PM
03/20/10 10:08 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
ive had the 440source sfi balancer for 4 years or so. No problems
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: 493_DART] #646073
03/20/10 10:38 PM
03/20/10 10:38 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: WILD BILL] #646074
03/20/10 10:59 PM
03/20/10 10:59 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Be careful with the Professional Products balancer. I put one of their SFI balancers on the cast crank 440 in my wife's car since the OEM piece was on the ratty side and the engine honestly did not warrant spending a ton of money on a 'good' unit. It's been on the car for about 4 years, but over the winter I noticed the outer ring of the Professional Products balancer would move left or right about 1/8".
I sent an email to Professional Products customer service dept asking if anybody else had an issue with this happening. They did not really give me an answer, but they did send me a brand new balancer with no questions asked. I did not have to prove I even had their balancer...just said I had that problem and a new one showed up on my doorstep. I figured they would want the old one back. Nope.
The replacement is on the engine now. So far so good, but the balancer is not degreed accurately. As an example, 36 degrees actually reads 38 on the balancer.
I was obviously not expecting a quality piece for that kind of bargain basement price, but at least their customer service is great.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: VernMotor] #646075
03/20/10 11:03 PM
03/20/10 11:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... the summit one took a poop..
Which Summit balancer? IIRC they offer more than one SFI version, a "cheapie" and a $300+ model that I've heard is made by Cyco / Pro Race.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: BradH] #646076
03/21/10 07:41 AM
03/21/10 07:41 AM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
Been happy with all my 440 source stuff! About the only thing I can say about the source balancer is it fits tighter than it needs to. I hear tell this is common with other off shore brands too.
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: BradH] #646077
03/21/10 09:25 AM
03/21/10 09:25 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yes it was the cheaper one bracket race 165.00 lasted 300 runs about 1 1/2 years..never over 6000rpm 500 hp motor.
http://www.summitracing.com/parts/SUM-C4279/
Re: 440 Source SFI Harmonic Balancer (BB) Experience [Re: Maximus_Wedges] #646078
03/21/10 01:47 PM
03/21/10 01:47 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Got one my Hemi and it took a lot of fitting to get it on.
