Re: Largest bore on a stock 318.
[Re: Moparnut426]
#645017
03/19/10 01:37 PM
03/19/10 01:37 PM
Posts: 3,505 DFW
mr_340
DFW
Why not put a stroker crank in it instead of the big bores? I guess if you ruin a 318 block you haven't lost much except the machining costs.
Floyd Lippencott IV
[Re: mr_340]
#645018
03/19/10 01:49 PM
03/19/10 01:49 PM
Posts: 543 Indiana, Just Off I-70
BradD
I've been thinking about this lately too! What to do with original forged 340 cranks? I was thinking offset grind to 1.88 and use the plentyful 6.3 rods from the used NASCAR shops. The piston weight needs to be less than 440g from what I understand from the rod makers. I believe 3.79 stroke may be doable starting with a non ground journal. Possibly use a Ford Windsor shelf piston. I already have a 3.79 mopar crank that has to have the journals cut to 2". I have used Lentz 6.20 rods. I hope to use them sometime this year.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: Moparnut426]
#645020
03/19/10 02:05 PM
03/19/10 02:05 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Sonic test it.. I think it's a "your results may vary" deal there... I've heard of them going to 4" bores. Never a 4.04 but if it's thick enough why not?
[Re: BradD]
#645022
03/20/10 10:34 AM
03/20/10 10:34 AM
Posts: 4,212 New York
polyspheric
New York
Math: 2.125 - 1.88 = .245". Assuming zero error/perfect alignment, the maximum stroke increase is .245", or 3.555".
Boffin Emeritus
[Re: Moparnut426]
#645023
03/20/10 10:35 AM
03/20/10 10:35 AM
polyspheric
New York
.150" on the thrust axis makes me nervous.
Boffin Emeritus
[Re: tjmarcus1]
#645024
03/20/10 10:37 AM
03/20/10 10:37 AM
polyspheric
New York
318 3.91" > 340 4.04" Result: 85% leakdown, poor oil control, high crankcase pressure. Don't.
Boffin Emeritus
