Largest bore on a stock 318. Crank question also... #645013
03/19/10 12:45 PM
03/19/10 12:45 PM
Finally a HUSKER again
Moparnut426 Offline OP
So what is the largest bore you gys have cut in a stock 69318 block? We are trying to get a 4" bore with our magnum xl 3.31 crank. We are trying to get in the 330-340 ci range.
Kasey
Re: Largest bore on a stock 318. [Re: Moparnut426] #645014
03/19/10 12:50 PM
03/19/10 12:50 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
a buddy of mine has done a bunch of those. bored them to stock 340 bore.{not real high hp.}
Re: Largest bore on a stock 318. [Re: tjmarcus1] #645015
03/19/10 01:04 PM
03/19/10 01:04 PM
I know of guys running the same set up with an x block and buzzing them 82-8500 making strong 450-500 hp on a 2bbl in their late models
Its all in the camshaft, compression, and the W2 head makes up the rest.
We are limited to compression, and no porting, but acid porting is accepted way of cleaning up casting flaws. the W2 flows 40 more CFM box stock over the Bowtie head allowed in the chevys. This thing is gonna sing.
our budget isnt alowing us to use an x block, or the R block thats legal. We have a 340 block laying around but cant bring ourselvs to possibly destroying a good block.
Kasey
Re: Largest bore on a stock 318. [Re: Moparnut426] #645016
03/19/10 01:23 PM
03/19/10 01:23 PM
If we offset grind the crank from the 2.00 chevy pin tothe 1.88 honda pin what can we get with the 3.31 crank.
KAsey
Re: Largest bore on a stock 318. [Re: Moparnut426] #645017
03/19/10 01:37 PM
03/19/10 01:37 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Why not put a stroker crank in it instead of the big bores? I guess if you ruin a 318 block you haven't lost much except the machining costs.
Floyd Lippencott IV
Re: Largest bore on a stock 318. [Re: mr_340] #645018
03/19/10 01:49 PM
03/19/10 01:49 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
I've been thinking about this lately too! What to do with original forged 340 cranks? I was thinking offset grind to 1.88 and use the plentyful 6.3 rods from the used NASCAR shops. The piston weight needs to be less than 440g from what I understand from the rod makers. I believe 3.79 stroke may be doable starting with a non ground journal. Possibly use a Ford Windsor shelf piston.
I already have a 3.79 mopar crank that has to have the journals cut to 2". I have used Lentz 6.20 rods.
I hope to use them sometime this year.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Largest bore on a stock 318. [Re: BradD] #645019
03/19/10 02:03 PM
03/19/10 02:03 PM
I cant run over a stock 3.58 stroke.
I have been looking at used lentz, and corillo rods.
Kasey
Re: Largest bore on a stock 318. [Re: Moparnut426] #645020
03/19/10 02:05 PM
03/19/10 02:05 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Sonic test it.. I think it's a "your results may vary" deal there... I've heard of them going to 4" bores. Never a 4.04 but if it's thick enough why not?
Re: Largest bore on a stock 318. [Re: moper] #645021
03/19/10 02:43 PM
03/19/10 02:43 PM
What is the min the sonic should yield what .150?
Kasey
Re: Largest bore on a stock 318. [Re: BradD] #645022
03/20/10 10:34 AM
03/20/10 10:34 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Math: 2.125 - 1.88 = .245".
Assuming zero error/perfect alignment, the maximum stroke increase is .245", or 3.555".
Boffin Emeritus
Re: Largest bore on a stock 318. [Re: Moparnut426] #645023
03/20/10 10:35 AM
03/20/10 10:35 AM
New York
polyspheric Offline
polyspheric  Offline
New York
.150" on the thrust axis makes me nervous.
Boffin Emeritus
Re: Largest bore on a stock 318. [Re: tjmarcus1] #645024
03/20/10 10:37 AM
03/20/10 10:37 AM
New York
polyspheric Offline
polyspheric  Offline
New York
318 3.91" > 340 4.04"
Result: 85% leakdown, poor oil control, high crankcase pressure.
Don't.
Boffin Emeritus
