aluminum washers for external oil pick ups? #643716
03/18/10 03:28 AM
03/18/10 03:28 AM
Chesterfield Twp. Mi.
John Burdine Offline OP
who makes/sells the aluminum washers for use with an external oil system. was it Doty? i dont remember, who sells them?
Re: aluminum washers for external oil pick ups? [Re: John Burdine] #643717
03/18/10 04:44 AM
03/18/10 04:44 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Yes Doty, I got mine through performance only racing.
Re: aluminum washers for external oil pick ups? [Re: John Burdine] #643718
03/18/10 08:23 AM
03/18/10 08:23 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I am pretty sure I bought mine from Greg Z.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: aluminum washers for external oil pick ups? [Re: Dap] #643719
03/18/10 09:03 AM
03/18/10 09:03 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
DMI makes that washer kit ; pn DMOSK012 ($12.99)
http://www.dotymi.com/Automotive_Home.htm
Mancini carries DMI products, you can probably order through them or from DMI direct.
Ron
Re: aluminum washers for external oil pick ups? [Re: John Burdine] #643720
03/18/10 09:15 AM
03/18/10 09:15 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
A good time/place to ask this question ...
What do you use on the inside of the pan - just the pickup block ???
Re: aluminum washers for external oil pick ups? [Re: Stanton] #643721
03/18/10 09:39 AM
03/18/10 09:39 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I smear a coating of the "Right Stuff" on the pickup block were it pulls against the pan, then a I also smear some on the threads of the fitting that screw in the block.
Re: aluminum washers for external oil pick ups? [Re: Bob_Coomer] #643722
03/18/10 10:57 AM
03/18/10 10:57 AM
sg66mopar Offline
sg66mopar  Offline
Just an O-ring here.
Re: aluminum washers for external oil pick ups? [Re: sg66mopar] #643723
03/18/10 11:35 AM
03/18/10 11:35 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Anyone try a sealing washer? I hope the link works.
http://www.mcmaster.com/#sealing-washers/=69sxup
Looks like you would have to click on the pressure sealing washers. I can't get it to come up with a specific page. The McNasty site is weird like that.
Floyd Lippencott IV
Re: aluminum washers for external oil pick ups? [Re: mr_340] #643724
03/18/10 02:01 PM
03/18/10 02:01 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Sealing washers similar to the above.
Not the best pic but you can sorta make them out.
The DMI kit wouldn't work because of the ribs on the pan. They work fine on another motor though.
Re: aluminum washers for external oil pick ups? [Re: Tig] #643725
03/18/10 03:53 PM
03/18/10 03:53 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i bought some yellow plastic bar stock thats impervious to oils & fuel & just made the washers i wanted on a lathe. i used to have a drip on my oil fitting with the O ring but with these plastic type washers it's been great. they also clean up like new when we freshen up the engine. i think they've been recycled 5-6 times now & still no leak.
Re: aluminum washers for external oil pick ups? [Re: Tig] #643726
03/18/10 04:07 PM
03/18/10 04:07 PM
under a rock
flathood Offline
flathood  Offline
under a rock
White nylon washer here
Re: aluminum washers for external oil pick ups? [Re: flathood] #643727
03/18/10 04:54 PM
03/18/10 04:54 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
White nylon washers here too.............
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
