Ok here is the situation, as the new season is coming around i am switching from a stock style devision to a pretty much open class.
i currently am running a 440 with a 4.15 crank, 4.375 srp flat top dual v/r piston that is set .012 in block with a .990 pin on eagle h beams, topped off with eddy rpm 84 cc's which have been cut .050.
now the issue is i am looking to bump it up to the most hp and torq i can, without throwing all my money out the door starting from scratch.
the rules for my new class is 500ci( which im already close to)
single carb only no efi
race gas only no alco,eth,meth and such.
motor must be n/a
i am looking to get hopefully at least 700 hp range with what ever i do. will i be able to get close with a .650ish cam,zero deck,cutting the heads some more and haveing dwayne work his magic on the heads? or am i in a whole diffrent ball park?
any help would be great
