Page 1 of 4 1 2 3 4
440 Source Stealth Heads #642793
03/17/10 07:47 AM
03/17/10 07:47 AM
Ohio
I
iron6 Offline OP
iron6  Offline OP
I
Ohio
Ok after waiting a year porting and flowing my Stealth Heads! I thought I was ready to bolt them on. FOLLOWING the directions in the box from 440 Source, buying correct gaskets, changing to 928 springs and 10 degree retainers, following the prescribed #torque. I was ready to set the valve lash. It was fine until setting the Intakes there wasn't enough clearance for the 3/8 pushrod. Now what? Call 440 Source and the answer is!!!! Oh didn't anyone tell you when you bought them you have to clearance the intakes??????? NO NO and NO. Not on the install sheet, not in the add and certainly not when I order. Advertisement read great heads bolt on the power. THANKS 440 Source!!!!!!!!!! Is there anything else I need to know before I fire and make a run down the track??????
Re: 440 Source Stealth Heads [Re: iron6] #642794
03/17/10 07:56 AM
03/17/10 07:56 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Yeah, check everything twice before assembly. No aftermarket part is " bolt on " and go in my experance. Check it all. Then check it again. And if in doubt call the tec line.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 440 Source Stealth Heads [Re: yella71] #642795
03/17/10 09:27 AM
03/17/10 09:27 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I agree, no part is bolt on with out checking. Especially aftermarket.
Re: 440 Source Stealth Heads [Re: ireland383] #642796
03/17/10 09:39 AM
03/17/10 09:39 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Right....and the aftermarket is not accountable for quality.
More Kool aid?
Re: 440 Source Stealth Heads [Re: iron6] #642797
03/17/10 09:59 AM
03/17/10 09:59 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
So did the Edelbrock heads when using 1.6 rockers.
Just get out the grinder and live happily ever after. Or, upto the next snatch ofcourse.
Re: 440 Source Stealth Heads [Re: BigBlockMopar] #642798
03/17/10 10:03 AM
03/17/10 10:03 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
We had to grind my Eddy's for clearence.
Re: 440 Source Stealth Heads [Re: WILD BILL] #642799
03/17/10 10:21 AM
03/17/10 10:21 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
My Stealths fit with the 3/8 push rods.They are super close but dont touch.As said always check everything.I also changed me locks, springs and retainers.My machinist also back cut the valves and cleaned them a bit.Would have done it with just about any head.Rocky
Chrysler Firepower
Re: 440 Source Stealth Heads [Re: therocks] #642800
03/17/10 11:54 AM
03/17/10 11:54 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
So you're surprsied a non-stock pushrod side won't fit? I wouldn't be, but for the price and considering it's an aftermarket part you'd think they'd have worked that into the design.
Re: 440 Source Stealth Heads [Re: iron6] #642801
03/17/10 12:30 PM
03/17/10 12:30 PM
Ohio
I
iron6 Offline OP
iron6  Offline OP
I
Ohio
The challenge wasn't they needed clearanced. When you look at them it looks like they'll clear until you bolt them on and put the rocker shafts on to set vash lash. They put everything on the install sheet but check the clearance. Just trying to put info out there for the next guy. I've been checking out the info on the Stealth heads for over a year and never saw a post on clearance problems. All and all they came out nice we'll see what the improvement is in two weeks at T&T. I'm really not trying to be negective about the heads.
Re: 440 Source Stealth Heads [Re: iron6] #642802
03/17/10 12:36 PM
03/17/10 12:36 PM
Manitoba, Canada
Manitoba, Canada
Install sheet? I never got no install sheet. Just a set of heads in a box.
Re: 440 Source Stealth Heads [Re: iron6] #642803
03/17/10 01:57 PM
03/17/10 01:57 PM
AndyF Offline
AndyF  Offline
Try a set of Victor heads!
Re: 440 Source Stealth Heads [Re: AndyF] #642804
03/17/10 02:45 PM
03/17/10 02:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I just hand ported a set for a friend and stealths definately are not Edelbrocks. I clearanced the pushrod holes while I was at it so I hope he has no issues on test fit.
I had to do my Indy SR's too but like you found out after assembly!!! LOL!!!
Re: 440 Source Stealth Heads [Re: Dodgem] #642805
03/17/10 02:48 PM
03/17/10 02:48 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
...and stealths definately are not Edelbrocks.
Not to slam anyone but just wondering what that meant.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 440 Source Stealth Heads [Re: HealthServices] #642806
03/17/10 03:22 PM
03/17/10 03:22 PM
michigan woods
imfixinmopars426 Offline
michigan woods
i just would like to know what needs attention on these heads? i understand they need the standard "blueprint"..ck valve job,guides/stems clearance,straightness, installed height,proper springs for cam,maybe backcut the valves?,...but is there any other things besides pushrods?....and the most of all how is the stock and ported stealth airflow vs 906.+.ported 906 big valves! actual numbers,and or hp increases please...i cant be the only one interested. not really interested in ede's...looking for stock look.
Re: 440 Source Stealth Heads [Re: HealthServices] #642807
03/17/10 03:52 PM
03/17/10 03:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Not nearly as nice kinda crude (well Chinese so to speak) no way an OOTB Stealth will flow what and OOTB eddie will.
Re: 440 Source Stealth Heads [Re: Dodgem] #642808
03/17/10 05:13 PM
03/17/10 05:13 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Oh here we go again. I'll take Stealths any day over Eddies for price.
Re: 440 Source Stealth Heads [Re: Dodgem] #642809
03/17/10 05:20 PM
03/17/10 05:20 PM
Manitoba, Canada
Manitoba, Canada
Not to start a but do you have the flow numbers to back up that claim? Because the numbers I have, done by a respected moparts head porter, show OOTB eddy vs OOTB stealth to be within +/- 4% of each other across the board.
Re: 440 Source Stealth Heads [Re: ireland383] #642810
03/17/10 05:25 PM
03/17/10 05:25 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
SOUNDS LIKE you have run into some POOR QUALITY stuff.
IMO ...if you buy an "assembly" that is claimed to be BOLT-ON ... it should not need additional "checking".
Re: 440 Source Stealth Heads [Re: dOrk !] #642811
03/17/10 05:54 PM
03/17/10 05:54 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
A neighbor just bought a set of Stealth heads...VERY nice.He is changing the springs and locks and such as he is running a large cam,but he brought them to the machine shop to make sure everything with the valve job and guide clearance was good and they were just fine.
Nautilus Racing-
Re: 440 Source Stealth Heads [Re: imfixinmopars426] #642812
03/17/10 06:20 PM
03/17/10 06:20 PM
Ohio
I
iron6 Offline OP
iron6  Offline OP
I
Ohio
My 906's ported by COMP U Flow on his bench flowed 258 intake and 210 exhaust @ 600 lift. On a 472 Stroker with 640 lift cam ran 10.96 with a 3465# 67 Dodge at Norwalk CC event last season.
The Stealth Heads ported, I just put on flowed 284 Intake and 214 Exhaust @ 600 lift. In two weeks I'll let you know what the difference is. One thing for sure there is 40# off the front of the car. Thanks for all the comments see you all in Columbus, OH in May.
Page 1 of 4 1 2 3 4
