Edelbrock heads ?? #642610
03/17/10 01:30 AM
03/17/10 01:30 AM
Tucson, Arizona
johnnyrotten Offline OP
Tucson, Arizona
I am currently bolting my junk back together to go to MATS and want some opinions on Edelbrock heads compared to a set of moderately worked 915's. I have a set of Eddie's laying around and I am thinking of throwing them on my 440. Here is a short spec list, trw 2295's, 304/272@50-555" solid cam, and basic oiling system. The 915's had stock sized stainless valves and were basically cleaned up and gasket matched. I ran it with an M1 intake and a 950hp holley. What gain do you potentially see from the edelbrocks? I also have a victor I could put on as well. All opinions welcome
Re: Edelbrock heads ?? [Re: johnnyrotten] #642611
03/17/10 04:41 AM
03/17/10 04:41 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
You cant go wrong with the modern aluminum heads compared to outdated , crack prone iron heads. As far as I know an out of the box Rpm head will make similar power to a ported factory iron head.
Bolt em on !
Depending on the car combo, even the lower $ Eddy Rpm's or 440 source heads can go REAL quick at the track.
Re: Edelbrock heads ?? [Re: johnnyrotten] #642612
03/17/10 05:12 AM
03/17/10 05:12 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
My car picked up a solid .2 plus when I went from ported 906's with big valves to edelbrock rpm's with just a light port clean up.
Re: Edelbrock heads ?? [Re: johnnyrotten] #642613
03/17/10 06:22 AM
03/17/10 06:22 AM
two tenths + and four MPH on my first run after swapping to a set of Eddy RPM CNC ported by MCH with no other changes
Re: Edelbrock heads ?? [Re: Cab_Burge] #642614
03/17/10 02:03 PM
03/17/10 02:03 PM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
Be advised that the L2295F piston has a small dome with a centralized spark plug relief, and the Eddys have angled spark plugs that might contact the dome. I have never checked for this, but you should. Even a Ross domed piston has to be relieved to clear an Indy head's angled plugs... RB
Re: Edelbrock heads ?? [Re: Bighead440] #642615
03/17/10 04:47 PM
03/17/10 04:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, my Eddy 84cc heads didn't flow their advertised #s OOTB, but they did respond pretty well to bowl & port work.
(Mine is a 440-port motor, not a Max Wedge deal).
I'm an aluminum fan when it comes to heads, for weight, port-work & repairability. I use the FelPro composite (1009?) gaskets, not metal, and run double springs.
Re: Edelbrock heads ?? [Re: topside] #642616
03/17/10 04:53 PM
03/17/10 04:53 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I don't recall them listing an advertised flow #. All I recall is the advertised CC of the runners.
Re: Edelbrock heads ?? [Re: WILD BILL] #642617
03/17/10 05:06 PM
03/17/10 05:06 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Bill I think in the beginning, they were hyping flow numbers in the magazine ads of 290-something. I've had three sets on two different benches that were no where close to that...
But to Johhny's question, they should be a gain over all but the most advanced OEM head...
Re: Edelbrock heads ?? [Re: cudadoug] #642618
03/17/10 05:35 PM
03/17/10 05:35 PM
Boston,MA Area
Chris_R/T Offline
Chris_R/T  Offline
Boston,MA Area
Yeah, they're saying 292. Scroll to the bottom
http://www.edelbrock.com/automotive_new/mc/cylheads/chrysler/bb_perf_rpm.shtml
Doesn't give much info as to how they got those numbers though
Re: Edelbrock heads ?? [Re: Chris_R/T] #642619
03/17/10 05:43 PM
03/17/10 05:43 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
How in the world did they figure that
IIRC mine folwed 268 OOTB
BTW Chris R/T
Re: Edelbrock heads ?? [Re: WILD BILL] #642620
03/17/10 05:45 PM
03/17/10 05:45 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
BTW Chris R/T
well..you never know how many sets of heads to find the one that flowed the most....LOL
Tony
70 AARCuda Vitamin C
Re: Edelbrock heads ?? [Re: 70AARcuda] #642621
03/17/10 05:47 PM
03/17/10 05:47 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
The mystical 1 of 1 eddy head that was never reproduced
Re: Edelbrock heads ?? [Re: WILD BILL] #642622
03/17/10 08:41 PM
03/17/10 08:41 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
John Boy, Quit being a wussy and bolt on those old iron -1's on it!!! It will keep the front end down and plant you in the seat in high gear. You have everything to bolt them on so "do it"
Re: Edelbrock heads ?? [Re: johnnyrotten] #642623
03/17/10 09:19 PM
03/17/10 09:19 PM
Tucson, Arizona
Tucson, Arizona
Thanks for the replies. I had a similar shortblock to this with eddie's on it and was not impressed at all. Looking at them, I only see the weight,angle plug and smaller valve stem size as a benefit. The ports are far from impressive I will bolt them on and see what happens. If it's a turd I will spray the life into it
Bill, I have all the 470 parts together now, just need to get the block work done.I plan on stuffing that in sometime this fall. This engine will be my backup junker. Just want to go play untill then
Re: Edelbrock heads ?? [Re: WILD BILL] #642624
03/17/10 09:34 PM
03/17/10 09:34 PM
BTW Chris R/T
The 292 was for the max wedge heads was it not?
Re: Edelbrock heads ?? [Re: cudadoug] #642625
03/17/10 10:17 PM
03/17/10 10:17 PM
ill
dennismopar73 Offline
ill
well i havent flowed my new ones i just got but
the past ones flowed pretty close to 285 -289
if you go by the numbers the eddies way out perform any stock head
Re: Edelbrock heads ?? [Re: dennismopar73] #642626
03/17/10 10:20 PM
03/17/10 10:20 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
Cool! See you and Pop in Vegas
Re: Edelbrock heads ?? [Re: stockerbill] #642627
03/18/10 08:09 PM
03/18/10 08:09 PM
CA, USA
JcodeCharger Offline
CA, USA
Just to reinforce what others are saying. My small block Eddies flowed 217 stock on the intake with a 4.03 bore plate. Not 255cfm that Eddy says. I called the tech line and their response is that their numbers are accurate to 10% and that they use a 4.125 bore. That means they take the real number and inflate it 10%. I was really disappointed with the outcome. My J heads flow 255 and to put the eddys on would probably go slower.
68 twin turbo Dart 8.19 so far
70 Swinger 360
69 Roadrunner 383 4 speed
69 Mod Top Satellite 383 auto
69.5 A12 Super Bee 4 speed
70 T/A Challenger
70 FC7 Duster 340 4 speed
70 FJ5 Superbird
68 Hemi 4 speed Roadrunner
71 Duster W2 340
Re: Edelbrock heads ?? [Re: Chris_R/T] #642628
03/18/10 11:14 PM
03/18/10 11:14 PM
cudadoug Offline
cudadoug  Offline
They simply left out the part about the shop fan blowing another 30 cfm in there!! Or...to be fair to Edelbrock, maybe they used the bench at Westech...
Re: Edelbrock heads ?? [Re: cudadoug] #642629
03/18/10 11:36 PM
03/18/10 11:36 PM
ill
ill
im sorry
we are talking diff heads
mine are big block
i can not say what the small do
i ve heard from several that the small block
may n ot be as good
