Electronic Distributor Tear Down #64139
05/26/08 06:42 PM
05/26/08 06:42 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
How do you replace the coil pick up in the distributor? I had to get towed today, and the next thing to replace is this part. I've got the cap and rotor off, but now can't figure what to pull next, or in what order. I have a service manual, but that isn't much help. It's a 383 motor with the mopar electronic conversion setup. Factory electronic distributor. Can this be done without removing the distribuator?
Thanks.
1968 Plymouth Road Runner 383 4 speed
Re: Electronic Distributor Tear Down [Re: dobie] #64140
05/26/08 07:01 PM
05/26/08 07:01 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
You pry up the reluctor with two screwdrivers. Careful not to lose the small pin that indexes the reluctor to the shaft. Then you can slip the pick-up and its plate off. (after removing the lock screw of course)
Re: Electronic Distributor Tear Down [Re: Pacnorthcuda] #64141
05/26/08 07:05 PM
05/26/08 07:05 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
What about the shaft that the rotor fits on to? Does that need to come off first, or just take the rotor off, then pry off that plate underneath?
Re: Electronic Distributor Tear Down [Re: dobie] #64142
05/26/08 07:08 PM
05/26/08 07:08 PM
there is a ver small retaining ring in the center of the shaft, at the top under where the rotor slips over. It can be a [Edited by Moparts - Keep it clean] to get off, use very narrow needlenose. Then the top of the shaft comes off, that exposes the weights and springs.
Not a bad idea to have the dist out for this, just mark where the rotor is pointing, and a mark fo the timing (base to engine) and putting it back is easy.
Re: Electronic Distributor Tear Down [Re: Pacnorthcuda] #64143
05/26/08 07:13 PM
05/26/08 07:13 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Ok. Thanks. I'll head back out to the garage and look things over again.
Thanks.
Re: Electronic Distributor Tear Down [Re: dobie] #64144
05/26/08 07:27 PM
05/26/08 07:27 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
OK, I don't see a snap ring. Here's a pic of where I'm at...........
Re: Electronic Distributor Tear Down [Re: dobie] #64145
05/26/08 08:26 PM
05/26/08 08:26 PM
right down the center shaft should be a round piece of felt, take it out and the snap
ring is underneath. theres two slots on the reluctor gear. make a note which one the
lock pin went through. its actually pretty simple to do a MoPar distributor. if this is still
confusing.
Re: Electronic Distributor Tear Down [Re: Pacnorthcuda] #64146
05/26/08 08:32 PM
05/26/08 08:32 PM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
You don't have to mess with the clip in the center of the shaft. Just follow the instructions above from pacnorthcuda.
Re: Electronic Distributor Tear Down [Re: MadMax58] #64147
05/26/08 09:06 PM
05/26/08 09:06 PM
True, if all you're doing is the pickup, don;t mess with the clip ring! You only need to take the clip off to get to the weights.
Re: Electronic Distributor Tear Down [Re: Pacnorthcuda] #64148
05/26/08 11:02 PM
05/26/08 11:02 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Thanks to all. I figured it out, sort of. I didn't realize a piece was held on by a 3pt clip thing, and kept on prying. One of the 3 gold colored things ended up snapping off of course. By then I figured out I had 2 more screws to remove the whole assembly. Anyways, how important is that little thing I broke?? It actually kinda fell back in place, and I put everything back together. I figured I couldn't mess it up anymore, ya know? I never dreamed it would run again, but after everything went back on, she fired up pretty easy actually. The only thing is now I have a strange noise coming from up front. It sounds like something is caught in the fan; or similar to the old baseball card in the spokes' trick. I can't find any reason for it though. It's just like a rapid "clicking" noise. Anyways, thanks for the help so far.
