Electronic Distributor Tear Down
#64139
05/26/08 06:42 PM
05/26/08 06:42 PM
Posts: 1,032 Ohio
dobie
Ohio
How do you replace the coil pick up in the distributor? I had to get towed today, and the next thing to replace is this part. I've got the cap and rotor off, but now can't figure what to pull next, or in what order. I have a service manual, but that isn't much help. It's a 383 motor with the mopar electronic conversion setup. Factory electronic distributor. Can this be done without removing the distribuator?
Thanks.
1968 Plymouth Road Runner
383 4 speed
Re: Electronic Distributor Tear Down
[Re: Pacnorthcuda]
#64141
05/26/08 07:05 PM
05/26/08 07:05 PM
Posts: 1,032 Ohio
dobie
Ohio
What about the shaft that the rotor fits on to? Does that need to come off first, or just take the rotor off, then pry off that plate underneath?
383 4 speed
[Re: Pacnorthcuda]
#64143
05/26/08 07:13 PM
05/26/08 07:13 PM
Posts: 1,032 Ohio
dobie
Ohio
Ok. Thanks. I'll head back out to the garage and look things over again.
Thanks.
383 4 speed
[Re: dobie]
#64145
05/26/08 08:26 PM
05/26/08 08:26 PM
right down the center shaft should be a round piece of felt, take it out and the snap ring is underneath. theres two slots on the reluctor gear. make a note which one the lock pin went through. its actually pretty simple to do a MoPar distributor. if this is still confusing.
[Re: Pacnorthcuda]
#64146
05/26/08 08:32 PM
05/26/08 08:32 PM
Posts: 105 Baltimore, MD
MadMax58
Baltimore, MD
You pry up the reluctor with two screwdrivers. Careful not to lose the small pin that indexes the reluctor to the shaft. Then you can slip the pick-up and its plate off. (after removing the lock screw of course)
You don't have to mess with the clip in the center of the shaft. Just follow the instructions above from pacnorthcuda.
[Re: Pacnorthcuda]
#64148
05/26/08 11:02 PM
05/26/08 11:02 PM
Posts: 1,032 Ohio
dobie
Ohio
Thanks to all. I figured it out, sort of. I didn't realize a piece was held on by a 3pt clip thing, and kept on prying. One of the 3 gold colored things ended up snapping off of course. By then I figured out I had 2 more screws to remove the whole assembly. Anyways, how important is that little thing I broke?? It actually kinda fell back in place, and I put everything back together. I figured I couldn't mess it up anymore, ya know? I never dreamed it would run again, but after everything went back on, she fired up pretty easy actually. The only thing is now I have a strange noise coming from up front. It sounds like something is caught in the fan; or similar to the old baseball card in the spokes' trick. I can't find any reason for it though. It's just like a rapid "clicking" noise. Anyways, thanks for the help so far.
383 4 speed
