Re: Lifter bore repair: What bushing material?
[Re: ragtop]
#640804
03/15/10 03:37 PM
03/15/10 03:37 PM
bronze, .0015 press fit minumum
#640805
03/15/10 07:25 PM
03/15/10 07:25 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
There is another type of material that is harder (can't remenber the name) if it going to be street driven the bronze has a tendency wear Matt
[Re: MattW]
#640806
03/15/10 07:29 PM
03/15/10 07:29 PM
that's true. although many a car is being street driven with bronze bushings with no appreciable wear after many years.
#640807
03/15/10 07:30 PM
03/15/10 07:30 PM
MattW
Ontario Canada
Good to know
[Re: MattW]
#640809
03/15/10 07:50 PM
03/15/10 07:50 PM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
Ampco 18 aluminum bronze would be a good choice if you're going to make it yourself , it's very slick material.We use it all the time on plastic injection molds for bushings and wearplates. http://www.ampcometal.com/en/index.php?page=a18extThis may be the same material the use to make the distributor gear drives for roller cams.??
[Re: roadhazard]
#640810
03/15/10 07:55 PM
03/15/10 07:55 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
SAE 660 bronze is what I use.
RIP Monte Smith
[Re: CompWedgeEngines]
#640812
03/16/10 08:26 PM
03/16/10 08:26 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Same here...
