Lifter bore repair: What bushing material? #640803
03/15/10 10:16 AM
03/15/10 10:16 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I need to make a sleeve bushing for a worn lifter bore in my 340. What material and how much press fit? Thanks.
Re: Lifter bore repair: What bushing material? [Re: ragtop] #640804
03/15/10 03:37 PM
03/15/10 03:37 PM
bronze, .0015 press fit minumum
Re: Lifter bore repair: What bushing material? #640805
03/15/10 07:25 PM
03/15/10 07:25 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
There is another type of material that is harder (can't remenber the name) if it going to be street driven the bronze has a tendency wear Matt
Re: Lifter bore repair: What bushing material? [Re: MattW] #640806
03/15/10 07:29 PM
03/15/10 07:29 PM
that's true. although many a car is being street driven with bronze bushings with no appreciable wear after many years.
Re: Lifter bore repair: What bushing material? #640807
03/15/10 07:30 PM
03/15/10 07:30 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Good to know
Re: Lifter bore repair: What bushing material? [Re: MattW] #640808
03/15/10 07:49 PM
03/15/10 07:49 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Maybe Ampco 45 Bronze is a Nickel Aluminum Bronze
There is also a Manganese Bronze Ampco 673 & 674
fwiw
Re: Lifter bore repair: What bushing material? [Re: MattW] #640809
03/15/10 07:50 PM
03/15/10 07:50 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Ampco 18 aluminum bronze would be a good choice if you're going to make it yourself , it's very slick material.We use it all the time on plastic injection molds for bushings and wearplates.
http://www.ampcometal.com/en/index.php?page=a18ext
This may be the same material the use to make the distributor gear drives for roller cams.??
Re: Lifter bore repair: What bushing material? [Re: roadhazard] #640810
03/15/10 07:55 PM
03/15/10 07:55 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
SAE 660 bronze is what I use.
RIP Monte Smith
Re: Lifter bore repair: What bushing material? [Re: CompWedgeEngines] #640811
03/15/10 08:53 PM
03/15/10 08:53 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Try the Diamond site. They list lifter bushings on Page 5.
http://www.diamondracing.net/WristPinsSection.pdf
Floyd Lippencott IV
Re: Lifter bore repair: What bushing material? [Re: CompWedgeEngines] #640812
03/16/10 08:26 PM
03/16/10 08:26 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Same here...
Re: Lifter bore repair: What bushing material? [Re: CRE2004] #640813
03/17/10 01:50 AM
03/17/10 01:50 AM
New York
polyspheric Offline
polyspheric  Offline
New York
SAE 660 bronze
X3
Boffin Emeritus
Re: Lifter bore repair: What bushing material? [Re: polyspheric] #640814
03/17/10 04:25 AM
03/17/10 04:25 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
