Mopar Performance 452 Aluminum Heads Not As Advertised #639600
03/14/10 12:13 PM
03/14/10 12:13 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I just finished measuring the heads. Needless to say, I'm a little disappointed. Here's the actual CC's:
80.6 79.2
81.9 79.6
82.3 79.6
82.2 80
A far cry from the advertised 84cc. There is also a small hole in one of the chambers size of the point of a small pic. Will this cause a big problem for me? It's circled in Red.
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: kz5rt2] #639601
03/14/10 01:24 PM
03/14/10 01:24 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would not be complaining if my heads came in with slightly less CC than advertised, usually it's the other way around. The one head looks good, less than 1cc difference between the chambers but the other one looks like it needs to be squared and milled at a bit of an angle to bring them all together if you're concerned over that couple cc's of diff.
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: DaytonaTurbo] #639602
03/14/10 01:47 PM
03/14/10 01:47 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
What do you think about that little pin hole in the chamber? Will this cause a problem?
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: kz5rt2] #639603
03/14/10 02:08 PM
03/14/10 02:08 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Does it go through to anywhere or is it just a pine hole divot ??
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: Dodgem] #639604
03/14/10 02:12 PM
03/14/10 02:12 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
It's a divot. The hole doesn't go through.
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: kz5rt2] #639605
03/14/10 02:23 PM
03/14/10 02:23 PM
Manitoba, Canada
Manitoba, Canada
I wouldn't worry about that hole then. Chances are it'll get filled up with carbon not long after you start running the motor.
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: DaytonaTurbo] #639606
03/14/10 02:55 PM
03/14/10 02:55 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would be happy if the chambers were a CC or two small. I would not worry about the divot, seen that on many cast products and rarely causes a problem and that looks like one that is insignificant.
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: DaytonaTurbo] #639607
03/14/10 11:38 PM
03/14/10 11:38 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree its nothing to get all worried about. Ron
Re: Mopar Performance 452 Aluminum Heads Not As Advertised [Re: kz5rt2] #639608
03/15/10 10:21 AM
03/15/10 10:21 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
My Edelbrock RPM heads were the same way.
The advertised number is roughly the largest cc you're likely to ever see. Most will be slightly smaller.
Situation normal.
Mopar Performance 452 Aluminum Heads [Re: ZIPPY] #639609
04/15/10 01:39 PM
04/15/10 01:39 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Just a quick question. What would you guys recommend I run for a rocker assembly and pushrods?
Thanks!
Re: Mopar Performance 452 Aluminum Heads [Re: kz5rt2] #639610
04/15/10 01:47 PM
04/15/10 01:47 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That depends on cam selection + budget
Rich H.
Esse Quam Videri
Re: Mopar Performance 452 Aluminum Heads [Re: ZIPPY] #639611
04/15/10 04:03 PM
04/15/10 04:03 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I'll be running a Big Block Xtreme Energy Hyd.
RPM RANGE 1300-5600
ADV. DURATION 262/270
DURATION @ .050 218/224
VALVE LIFT .462/.470
LOBE CENTER 110
I also wanted to stay with a 1.5 ratio.
Re: Mopar Performance 452 Aluminum Heads [Re: kz5rt2] #639612
04/15/10 04:11 PM
04/15/10 04:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The MP HD stamped rockers are fine on an application like that, but they're on backorder right now and might be hard to find.
iron adjustable rockers would be a nice upgrade, but are a little harder to find now that Crane stopped making them. They seem to be fairly plentiful out there used, though.
For something fancier with a roller tip, Comp 1321 would work great also.... I have them on my rpm heads and really like them....but they're definitely overkill for a .470 lift application. Comp runs out of these on a regular basis, last time they ran out it was something like a 4 month wait.
Re: Mopar Performance 452 Aluminum Heads [Re: ZIPPY] #639613
04/15/10 05:02 PM
04/15/10 05:02 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
What would you recommend for pushrods?
Re: Mopar Performance 452 Aluminum Heads [Re: ZIPPY] #639614
04/17/10 03:15 PM
04/17/10 03:15 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I just installed the cam at 4 degrees advanced. Using the degree wheel, it's actually running 8 degrees advanced. Does anyone know if this is okay run, or should I get another timing chain or offset to run the intended 4 degrees?
Any help greatly appreciated!
Re: Mopar Performance 452 Aluminum Heads [Re: kz5rt2] #639615
04/17/10 04:36 PM
04/17/10 04:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Just back it up 4 degrees. It sounds like you installed it 8 degrees advanced.
If the cam manufacturer recommends an ICL, it is usally already ground into the cam.
Re: Mopar Performance 452 Aluminum Heads [Re: BSB67] #639616
04/17/10 04:57 PM
04/17/10 04:57 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
The only choice is +/- 4* on the cam, which gives 8 on the crank. Don't most timing chains have +/- 2* on the cam to give 4* on the crank?
