Re: Mopar Performance 452 Aluminum Heads Not As Advertised
[Re: DaytonaTurbo]
#639606
03/14/10 02:55 PM
03/14/10 02:55 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would be happy if the chambers were a CC or two small. I would not worry about the divot, seen that on many cast products and rarely causes a problem and that looks like one that is insignificant.
[Re: DaytonaTurbo]
#639607
03/14/10 11:38 PM
03/14/10 11:38 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I would not be complaining if my heads came in with slightly less CC than advertised, usually it's the other way around. The one head looks good, less than 1cc difference between the chambers but the other one looks like it needs to be squared and milled at a bit of an angle to bring them all together if you're concerned over that couple cc's of diff.
I agree its nothing to get all worried about. Ron
[Re: kz5rt2]
#639610
04/15/10 01:47 PM
04/15/10 01:47 PM
Posts: 17,842 S.E. Michigan
ZIPPY
S.E. Michigan
That depends on cam selection + budget
Rich H.
Esse Quam Videri
