"OOTB" Eddy heads issues #638939
03/13/10 04:15 PM
03/13/10 04:15 PM
California
fst340rt Offline OP
fst340rt  Offline OP
California
I have a new set of Eddy heads (6077) and since I will be using stock NON adjustable rockers I decided to check the valve stem tips with a straightedge to make sure that they are even.
I found that the intake valve tip on cyl.#5 is .005" higher than the rest. On the other head I found that the intake valve tip on cyl.#2 is .007" higher than the rest. In a smaller scale most of the other tips don't do much better...
Are there any tolerances that apply here or should I take them to a machine shop for correction that seems to be common with these "Precision-Machined" heads.
I'll appeciate your replies.
Re: "OOTB" Eddy heads issues [Re: fst340rt] #638940
03/13/10 04:31 PM
03/13/10 04:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most times its best to have them checked.I know they had a problem with tight guides.There really is no such thing as out of the box.Best to at least have them checked.They are mass produced and tolerances arent that great.Rocky
Chrysler Firepower
Re: "OOTB" Eddy heads issues [Re: therocks] #638941
03/13/10 06:11 PM
03/13/10 06:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The hydraulic lifters will easily eat up that little difference and your motor will never know it. I would be more concerned with actual valve spring installed height, quality of the valve job and how tight the valve guides are. Really a lot of guys run them OOTB I'm sure.
Re: "OOTB" Eddy heads issues [Re: DaytonaTurbo] #638942
03/13/10 06:58 PM
03/13/10 06:58 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I only checked p/v clearance when I pulled them out of the box and put them on. All good... no problems...
Re: "OOTB" Eddy heads issues [Re: DaytonaTurbo] #638943
03/14/10 11:43 PM
03/14/10 11:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree. My son took his heads out of the box and bolted them on. Ran it 3 years like that before he decided to do some mild porting on them. When we checked them they were good. Ron
Re: "OOTB" Eddy heads issues [Re: 383man] #638944
03/15/10 12:08 AM
03/15/10 12:08 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
been driving my 73 Duster with a set of OOTB eddy heads for a good 5 yrs now.
I am using a set of old crane ductile iron rockers arms.
Tony
70 AARCuda Vitamin C
Re: "OOTB" Eddy heads issues [Re: fst340rt] #638945
03/15/10 12:52 AM
03/15/10 12:52 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
FWIW, I doubt very much that the oem iron heads were any closer when they were new. In fact, I'd be surprised if they were even that close.
As mentioned, the lifters will take that up.
Re: "OOTB" Eddy heads issues [Re: dave571] #638946
03/15/10 07:34 AM
03/15/10 07:34 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Just my opinion but if the seat heights are off, seems to me the guides and seat concentricity might be off too. That's what I usually find and thats' why i have every set corrected. I didnt buy $1600 worth of head to not get everything I can for it.
Re: "OOTB" Eddy heads issues [Re: moper] #638947
03/15/10 02:37 PM
03/15/10 02:37 PM
California
fst340rt Offline OP
fst340rt  Offline OP
California
Thank you for your replies .My engine is a 340 that has been zero decked using trw forged pistons and an XE 268 cam and #822 hyd. lifters.
Ok,this is what I've done so far (more bad news) .I installed the heads using arp bolts and Felpro 1008 gaskets.I used an adjustable pushrod to find zero lash between rocker and lifter using the recommended procedure. I also used the EO/IC method for correct base circle location.
I checked each one of the eight cylinders for pushrod length using an 8" digital caliper and here are the results .
INTAKE ~ 7.437"/7.415"/7.445"/7.418"//7.427"/7.438"/7.426"/7.437"
EXHAUST ~
7.434"/7.445"/7.452"/t442"//7.447"/7.429"/7.451"/7.425"
I must add that I double checked and triple checked with consistent results.
So what's next ? A possibilty appears to be using a set of custom made pushrods ( Smith Bros. comes to my mind) for a 030" to 040" preload recommended by CC for the 822 hyd. lifters that I will be using.
Or maybe I should bite the bullet and buy another set of 1008 gaskets and take my heads to a ( reputable)machine shop and get everything squared away ( $$$ addition to the $1600 as suggested by Moper).
Hmm... where did I put those those 'X' heads?
Re: "OOTB" Eddy heads issues [Re: fst340rt] #638948
03/15/10 03:10 PM
03/15/10 03:10 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think this is why they recomend adj rocker arms. I have two sets currently running on my cars. 340 & 440 Eddie heads. I use adj rockers on both and both sets have performed great out of the box. I used stock push rods.
Re: "OOTB" Eddy heads issues [Re: Challenger 1] #638949
03/15/10 03:33 PM
03/15/10 03:33 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
You can use adjustable pushrods. I don't know who makes them anymore,,you can search, there was a thread on them..
For what you're doing they will work just fine, then you can get your "perfect" pushrod lenght.
Re: "OOTB" Eddy heads issues [Re: RemCharger] #638950
03/15/10 04:41 PM
03/15/10 04:41 PM
California
fst340rt Offline OP
fst340rt  Offline OP
California
Adjustable pushrods are hard to get anymore there must be a reason. Anyway ,I called Smith Bros.And yes they do make them but they do not recommend them for my application reason? not strong enough.Thank you anyway .
Re: "OOTB" Eddy heads issues [Re: fst340rt] #638951
03/15/10 05:01 PM
03/15/10 05:01 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: "OOTB" Eddy heads issues [Re: Dodgem] #638952
03/15/10 05:44 PM
03/15/10 05:44 PM
California
fst340rt Offline OP
fst340rt  Offline OP
California
http://www.summitracing.com/parts/CRO-70009-16/
or small block
http://www.summitracing.com/parts/CRO-70006-16/
According to Summit , the cro-70006 are designed to fit Small blocks with SOLID lifters and non-adjustable rockers.
