FWD 4cyl to RWD conversion? #638641
03/13/10 09:23 AM
03/13/10 09:23 AM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
Anybody know of a kit or? to convert mopar 4cyl fwd to RWD? I know there the Dakota trans stuff works but goodluck finding that stuff. Is there a vendor who makes conversion stuff?
4bbl If you can't hear it coming what's the point.......
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638642
03/13/10 10:43 AM
03/13/10 10:43 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That would be a no
Don't be the exception.
Re: FWD 4cyl to RWD conversion? [Re: Supercuda] #638643
03/13/10 10:47 AM
03/13/10 10:47 AM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
Mopar had a converion kit in the 80's, if you could find one.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: FWD 4cyl to RWD conversion? [Re: Bakaruda] #638644
03/13/10 11:06 AM
03/13/10 11:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No they didn't.
What he wants is to put a FWD engine in a RWD application.
What you are talking about is a "kit" to replace all the FWD junk with a V8 and RWD in a FWD car, opposite of what he wants.
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638645
03/13/10 11:26 AM
03/13/10 11:26 AM
IMGTX Offline
IMGTX  Offline
If I read this right you want to take a FWD 4 cylinder and bolt it in place of a V8/6 to make a 4cylinder RWD car/truck?
What kinda car or truck would you want to do this too?
Re: FWD 4cyl to RWD conversion? [Re: Supercuda] #638646
03/13/10 12:44 PM
03/13/10 12:44 PM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
No they didn't.
I read he is wanting to put a V8 in a FWD car. I know of two people that have done it in a Plymouth Sundance. Both used the mopar kit and it worked.
4BBL please specify what car and what engine you are refering to, please.
Re: FWD 4cyl to RWD conversion? [Re: Bakaruda] #638647
03/13/10 12:47 PM
03/13/10 12:47 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes..mopar made a kit in the 80s that put a V8 in the sundance/daytona bodies...
trying to find one today...priceless.
Tony
70 AARCuda Vitamin C
Re: FWD 4cyl to RWD conversion? [Re: 70AARcuda] #638648
03/13/10 01:03 PM
03/13/10 01:03 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
There is a company making kits to convert 4cyl FWD cars into RWD V-8's. They advertise in MCG. Their kits are simliar, but more complete than the Mopar one from a few years ago.
Here ya go:
http://www.exlinecustomauto.com/Index.html
Google is your friend....
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638649
03/13/10 02:19 PM
03/13/10 02:19 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I saw a Daytona/Laser a few years back with a FOX ford suspension under it, the owner said it fit like it was made for it, he redrilled the stock upper mounts for the ford struts and fabbed up mounts for the K frame.
He didn't have a bar in it and the rear suspension was pretty simple too, ladder bars with cheap coil overs and a stock width A body 8.75.
Re: FWD 4cyl to RWD conversion? [Re: MoparJoe] #638650
03/13/10 03:46 PM
03/13/10 03:46 PM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
I want to use a FWD 4cyl (like a daytona turbo)in a home built small chassis with a RWD trans, manual.
Few years ago I saw daytona turbo that the owner had used a dakota auto on and was getting 9sec or so ets in the 1/4.
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638651
03/13/10 06:07 PM
03/13/10 06:07 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Moparts member dirt runs exlinecustomauto.com he sells the parts to convert a fwd to rwd. Pretty good kit and his uses the unibody of the car as the frame by adding in extra supports and frame connectors. Check out his website.
Re: FWD 4cyl to RWD conversion? [Re: DaytonaTurbo] #638652
03/13/10 07:50 PM
03/13/10 07:50 PM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
Thanks for clearing that up.
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638653
03/13/10 09:09 PM
03/13/10 09:09 PM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
Kugel Components makes Focus RWD conversion stuff. Saw it at SEMA in 2001.
Have a look and do what they did.
http://www.kugelkomponents.com/focus/focus.php
69 Road Runner 383/auto/N96 71 Demon 340/4 spd Would like to find a rust free Cuda body.
Re: FWD 4cyl to RWD conversion? [Re: DmanSRT71] #638654
03/13/10 09:33 PM
03/13/10 09:33 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: FWD 4cyl to RWD conversion? [Re: RodStRace] #638655
03/13/10 10:49 PM
03/13/10 10:49 PM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
Thanks!
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638656
03/13/10 11:12 PM
03/13/10 11:12 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
SlantZilla has a Daytona that he's setting up with a /6.
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638657
03/13/10 11:30 PM
03/13/10 11:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't think the 4 banger dak came with an automatic.
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638658
02/23/12 10:03 AM
02/23/12 10:03 AM
SC
P
Peteswarr Offline
Peteswarr  Offline
P
SC
I converted a Plymouth TC-3 (Dodge Omni fastback) to RWD. It cost me around $2500. All you need is a TC-3, the front subframes, wheel wells, floor and tunnel from a Fox body Mustang; a rear from a Dart, a 360, and a transmission; along with a few parts (depending on your likes and dislikes) ladder bars; and a few tools most importantly, a welding machine. I have driven it 48,000 miles and with the OD trans, I get 26 mpg, can cruise at 150 mph, do the quarter in less than 14 seconds (tires were too hard and slipped all the way - sticky tires will take care of that) Mopar Action liked it a few years ago.
Re: FWD 4cyl to RWD conversion? [Re: 70AARcuda] #638659
02/23/12 07:58 PM
02/23/12 07:58 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Calling it a "kit" was overly optomistic. It was more like a couple pieces of steel that needed a lot of fab work to make anything out of.
Re: FWD 4cyl to RWD conversion? [Re: 4bbl] #638660
02/23/12 08:47 PM
02/23/12 08:47 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Okay, who dug up the two year old post?
Still, I have some info for others who may be reading it...
When using a home built chassis, the info you gain here may be difficult to use.
These guys know how it's done: http://locostusa.com/forums/
- Stu Harmon
