B1 Valve Gear Geometry ??? #638077
03/12/10 04:23 PM
03/12/10 04:23 PM
sg66mopar Offline OP
Would you run these heads as is or buy the correct length intake valves and start over?
It looks like the exhaust valves are pretty happy where they are but look at where the roller tip sits on the intake valve.
The stands can't be shimmed up because then the springs/retainers will hit the under side of the rockers.
Lash caps on the exhaust would make the valve tip heights about even but the ex. are about where they need to be already and that won't fix the intake valve problem.
Intake
Exhaust
Re: B1 Valve Gear Geometry ??? [Re: sg66mopar] #638078
03/12/10 05:44 PM
03/12/10 05:44 PM
I think that I would shim them up to see how that helps and then deal with the issues on the retainers to rockers clearances and so on BTW, are these rockers the ones Koffel supplys with the kit? Just wondering, I buoght a poted kit two or three years ago and I have not got around to starting mocking that motor up yet
Re: B1 Valve Gear Geometry ??? [Re: Cab_Burge] #638079
03/12/10 06:14 PM
03/12/10 06:14 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Isn't there some blocks that go on there?
Re: B1 Valve Gear Geometry ??? [Re: supercomp] #638080
03/12/10 06:21 PM
03/12/10 06:21 PM
Yeah, there's normally a rocker stand at the end but I left it off so the rocker would show. The rest of the stands are in place and the shaft height is correct.
Re: B1 Valve Gear Geometry ??? [Re: sg66mopar] #638081
03/13/10 10:30 AM
03/13/10 10:30 AM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
You can't run them like that, if you do you will have the guides wore out in no time. Plus if you run the motor through a rotation and watch it will more than likely run the trunion off the back of the valve. I don't think that lash caps will fill that void. Looks like you will need a longer valve to get the right geometry. If you try and shim that mess you will run the intake off the front.
I can't believe they set the head up like that, the valves should be set up within a couple thou on valve height.
I'm not an expert just my opinion.
Re: B1 Valve Gear Geometry ??? [Re: sg66mopar] #638082
03/13/10 11:18 AM
03/13/10 11:18 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Whats the spring PN, installed height of the E & I and how high do you intend to wind it up?
BTW, the ex looks pretty close.
8.30's @3400 lbs
Re: B1 Valve Gear Geometry ??? [Re: Mike Swann] #638083
03/13/10 02:56 PM
03/13/10 02:56 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Dick, have you tried the lash caps?
Re: B1 Valve Gear Geometry ??? [Re: camastomcat] #638084
03/13/10 03:05 PM
03/13/10 03:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m not sure lash caps would help......the valve appears to be too long now. What about shimming the shafts to move the rocker outward more to get the roller closer to center?
Re: B1 Valve Gear Geometry ??? [Re: Thumperdart] #638085
03/13/10 04:01 PM
03/13/10 04:01 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Lash caps wont help...You need to correct th valve stem height problem first....This will require the head to have the seats machined correctly.
Then machine the stands or shim them to get the correct geometry....
They are correct, no way will that work currently.
The person who set the heads up should have checked that out IMO...
Re: B1 Valve Gear Geometry ??? [Re: sg66mopar] #638086
03/13/10 04:04 PM
03/13/10 04:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
No "band aid" solution I can think of is going to resolve that situation. Whomever did the prep work on the heads should have seen that coming and let the owner know it was going to need some $$$ and rethinking the parts combination to straighten that out. Just an IMO, naturally.
Re: B1 Valve Gear Geometry ??? [Re: Thumperdart] #638087
03/13/10 04:21 PM
03/13/10 04:21 PM
Lash caps on the intake would make the problem worse. If I put them on the exhaust side they would get the valve stem heights closer but the exhausts are real close to right already.
This morning I mocked up 1 intake and 1 exhaust with no springs installed so I could run the gear through it's travel easily and take some measurements.
The intake rollers get pretty close to centered on the valve tip at somewhere over half travel. Not right in my opinion but maybe workeable. If I can't get new valves here pretty fast I'll probably put it together this way and hope for the best 'til next season.
The exhaust valves are .100 shorter than the intakes. I think they are just about right as is so if I can run them without lash caps they will probably be OK.
If I was to run it this way it would mean two different length pushrods.
If I can get the shorter intake valves that'll mean I have a brand new set of 5.50" long, 11/32" stem, 2.40" diameter titanium intake valves that I'm into around $1000 for sale. Anybody interested?
Shimming the stands up probably won't work. As the shafts move up they get closer to the spring and retainer which eventually causes them to rub at the rocker radius and from prior experience I can tell you that's NOT good.
Also, that would still leave the problem of two different height valve tips and different length pushrods.
Re: B1 Valve Gear Geometry ??? [Re: sg66mopar] #638088
03/13/10 09:15 PM
03/13/10 09:15 PM
well, that's a mess for sure. i'm curious about the valve spring installed height on both the intake and exhaust. can you tell us what it is currently...
Re: B1 Valve Gear Geometry ??? #638089
03/13/10 09:42 PM
03/13/10 09:42 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
So why is Koffel backing away from this? there must be some reason he doesn't want to make it right. Did he do all the work? Help us understand what's going on. This sounds like an Indy story, not Koffel.
Re: B1 Valve Gear Geometry ??? [Re: camastomcat] #638090
03/13/10 10:28 PM
03/13/10 10:28 PM
DRAM, I'm going to measure that tomorrow. I broke both my pairs of Starrett dial calipers today. Had them since 1978! I'll set up everything and use a telescoping gauge and micrometer. My motor dude says the installed heights are both wrong.
Tom, Scott says they've been sending them out this way for years with no problems,
It's pretty hard to disregard what Mitchell says I need to do. Guy and Roy (Paola) have both been building serious race stuff for what, 40 years? Mitchell puts together 2000+ HP funny car motors that live as long as most bracket motors.
Guy's a good personal friend and he just wants to see my stuff live.
Re: B1 Valve Gear Geometry ??? [Re: sg66mopar] #638091
03/14/10 12:44 AM
03/14/10 12:44 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
That's not correct and I would not accept that "they have been building engine for XX amount of years and who are you to questions my experience" Bull crap.
#1 who cares what the installed height is ,if the valve length is wrong it will not work
#2 The intake is to long period .
#3 If they piled up the valve job so bad that the valve is .100 deep in the seat , they have no business selling heads. ( not to mention that you will have brutally bad air flow.
The B1 head is still a in line valve cylinder head. The intake and exhaust rocker arm have the same fulcrum point and are parallel in relationship with the valve .
You should have a 5.400" intake and a 5.400" exhaust .
Get on the horn and make them get you new valves.
The Koffels are pretty good at fixing there mistakes ,you just have to call them on it. ( If that was the vender that sold you the parts. )
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: B1 Valve Gear Geometry ??? [Re: go green] #638092
03/14/10 02:19 AM
03/14/10 02:19 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
100%
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: B1 Valve Gear Geometry ??? [Re: PUNK] #638093
03/14/10 03:20 AM
03/14/10 03:20 AM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
put lash caps on all the valves & shim the shafts as close as you can get to the retainers.if you keep these valves,you are not going to get around having diff pushrod lenths.or start over with longer exhaust valves.
Re: B1 Valve Gear Geometry ??? [Re: go green] #638094
03/14/10 09:03 AM
03/14/10 09:03 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Re: B1 Valve Gear Geometry ??? [Re: HardcoreB] #638095
03/14/10 10:59 AM
03/14/10 10:59 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Have you sent scott the pictures? Im sure once he sees this he will correct it.
Re: B1 Valve Gear Geometry ??? [Re: joshking440] #638096
03/14/10 11:16 AM
03/14/10 11:16 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Wow, that's a mess I would not try to make that work, take it apart and measure
