Looking for rotor eating brake pads/Cordoba swap? #637437
03/12/10 10:29 AM
03/12/10 10:29 AM
Smyrna,TN.
cudagregs Offline OP
Smyrna,TN.
Hey Guys,i'm looking for a set of Cordoba front brake pads. I want pads that are better than stock. That's all the local parts houses seem to have. I swapped the Cordoba front brakes onto my 70 barracuda. Still trying to figure out which master cylinder to use for manual disk. I can get a 1" bore A-body manual mc from a 70 dart from my local parts house. Would that work OK? Thanks...Greg
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: cudagregs] #637438
03/12/10 11:34 AM
03/12/10 11:34 AM
scratchnfotraction Offline
when I went disc on my 68 Dart I used the MP 4 bolt to 2 bolt adaptor
installed an alum 2 bolt MC from a 5th ave
I swaped a 74 dart prop valve on to the 68 Dart
used an adjustable brake rod
work very good and no problems
I suggest droping the 4 bolt MC for the newer style alum 2 bolt
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: scratchnfotraction] #637439
03/12/10 11:53 AM
03/12/10 11:53 AM
Smyrna,TN.
Smyrna,TN.
Thanks, I will check with my parts house on the 5th ave. mc.
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: cudagregs] #637440
03/12/10 12:11 PM
03/12/10 12:11 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use 69 70 disc masters for a C body on ours.I also use ceramic pads.They are tons better than stock type.Stops great even at 120.Advanced got my pads.Rocky
Chrysler Firepower
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: therocks] #637441
03/12/10 12:36 PM
03/12/10 12:36 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
HPS offers several different types of brake pads. Stock to very very grippy. I went somewhere in the middle and am happy.
Be careful the 5th ave MC is a 1 1/8"+/- bore which is a little big for a non-power set-up. You will lose pedal feel. I suggest keeping it around or just under an inch. Summit has a 7/8" MC for an early 90's Lebaron, Imperial, etc. I suggest that one.
http://www.summitracing.com/parts/DHB-M39476/
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: Viol8r] #637442
03/12/10 01:01 PM
03/12/10 01:01 PM
Smyrna,TN.
Smyrna,TN.
Who is HPS and how do i contact them? Thanks for the info. I pulled the piston out of my original manual mc and the diameter is 1". Advance has a 1" 70 dart manual drum mc that i believe will work.
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: cudagregs] #637443
03/12/10 01:18 PM
03/12/10 01:18 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I've run both raybestos sure stops and bendix CQ ceramics, both work well....
2017 Grand Cherokee Overland
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: cudagregs] #637444
03/12/10 01:59 PM
03/12/10 01:59 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Regarding the brake pad portion of your question. Which calipers are you using? Pin or slide type? Pin type have less of a pad selection IIRC.
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: cudagregs] #637445
03/12/10 02:01 PM
03/12/10 02:01 PM
AndyF Online content
AndyF  Online Content
Call the guys at Firm Feel. www.firmfeel.com
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: AndyF] #637446
03/12/10 02:36 PM
03/12/10 02:36 PM
Smyrna,TN.
Smyrna,TN.
I have the pin type calipers. I will check out Firm Feel....Thanks
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: AndyF] #637447
03/12/10 02:37 PM
03/12/10 02:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
EBC & Hawk both make better pads; the EBC "Green Stuff" are pretty popular among the road-course guys.
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: cudagregs] #637448
03/12/10 03:44 PM
03/12/10 03:44 PM
http://www.firmfeel.com/carbonme_b.htm
Firm Feel can also get you the master cylinder adapter as well as a late model two bolt master. Or check the for sale pages on here and get a complete conversion kit from Eberg.
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: AndyF] #637449
03/12/10 03:52 PM
03/12/10 03:52 PM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
firm feel pads
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: sparcy] #637450
03/12/10 05:13 PM
03/12/10 05:13 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
rockauto.com to save some $$.
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: HemiDave] #637451
03/13/10 12:14 PM
03/13/10 12:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Advanced can get ceramic pads for pin type.Thats what I have on my 65.Probally about 35 bucks for a set.I believe mine were Beddix.Id have to find the box.Rocky
Chrysler Firepower
Re: Looking for rotor eating brake pads/Cordoba swap? [Re: therocks] #637452
03/13/10 01:10 PM
03/13/10 01:10 PM
Smyrna,TN.
Smyrna,TN.
Thanks guys, i will check with Advance to see what they have. On their website they don't show any ceramic pads other than stock pads..Thanks
