Re: MP Air Cleaner Clearance
[Re: bobby66]
#636686
03/11/10 05:35 PM
03/11/10 05:35 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
I think Ford Motorsports makes a drop base in the correct diameter.
I've heard that too. It would be nice if I could buy just the drop base, as I've heard that the entire assembly is 60.00...
I'm running the MP air cleaner. It doesn't hit the hood, but it interferes with my underhood insulation pad.
Anybody know where I could get just the base, and what the Ford part # might be?
[Re: 318 Stroker]
#636689
03/18/10 03:39 PM
03/18/10 03:39 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
Yes it does work. Go to jegs, it is the $60 one part number 301 or 302 or something like that.
It works using the ford base w/ the mopar top, but not the other way around, the 13 filter is too big for the mopar 12.75 base...
[Re: 6T6Cuda]
#636690
03/18/10 04:22 PM
03/18/10 04:22 PM
Posts: 186 Kansas, USA
Venomvpr900
Kansas, USA
I have found a size that fits and is 3.5 inches tall. Wix part number 42043 it is also a heck of alot cheaper than the MP replacement I payed $7 compared to the almost $40 the Stealer wanted for a MP one. And it looks a hell of a lot better than the short one that came with the air cleaner.
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver
13.83 @ 96.36 1.98 60 ft
2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
[Re: Venomvpr900]
#636691
03/18/10 05:43 PM
03/18/10 05:43 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Don't know why a dealer would even try to sell P2863349 air filter element at any price, because it's not available (component only). Without the P, (just 2863349), it's 12.25 retail but has been discontinued because the last model year it was used in is 1969. There are, amazingly, a few dealers who still have it but not many. Any of these will work fine and are dirt cheap: WIX Part # 42044 FRAM Part # CA305 FRAM Part # CA305V As far as: Quote:
"The MP is an oddball size. WHY? More NON user friendly crap for us mopar guys to have to deal with! "
The same baseplate is used for both the unsilenced and the black finned MP air cleaner. That air cleaner baselate was stamped from original tooling used on 1969 340 darts, 1969 383 road runners w/o air grabber, etc. It's a stock air cleaner base and it uses a stock air cleaner element.
It's an oddball size because Mopars used oddball sizes in 1969.
GM used 14" which the rest of the aftermarket defaulted to, just like they defaulted to GM dimensions on almost everything else.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#636692
03/18/10 06:42 PM
03/18/10 06:42 PM
Venomvpr900
Kansas, USA
P5249011 is the current part number for the filter for cast aluminum air cleaners and they are still out there
