Engine Torque Strap??? #636662
03/11/10 01:42 PM
03/11/10 01:42 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline OP
P
Is an engine torque strap recommended on a mild 360, 4 speed, if it has the later spool mounts? Read here that it is recommended is you have a 4 speed. Didn't specify what type of engine mounts, biscuit or spool. Thanks in advance.
Re: Engine Torque Strap??? [Re: Pntastar69] #636663
03/11/10 02:18 PM
03/11/10 02:18 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well it's not going to hurt anything by installing a torq strap. My torq strap is old school, a piece of chain and I got in on there very tight.
Re: Engine Torque Strap??? [Re: DaytonaTurbo] #636664
03/11/10 02:50 PM
03/11/10 02:50 PM
Madrid, IA
hellrzr Offline
hellrzr  Offline
Madrid, IA
This reminds me that I have to tighten the chain on mine this year! I agree that it shouldn't hurt anything if really need or not.
Re: Engine Torque Strap??? [Re: Pntastar69] #636665
03/11/10 03:33 PM
03/11/10 03:33 PM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
I have an AlterKtion (so, spool mounts) with Poly mounts, a manual trans, and no torque strap. No problem.
Re: Engine Torque Strap??? [Re: fbernard] #636666
03/12/10 01:39 AM
03/12/10 01:39 AM
Bend, Oregon
67cuda340 Offline
super street
67cuda340  Offline
super street
Bend, Oregon
This is the one I use...
http://www.engine-swaps.com/
1973 Dodge Dart Sport 360 Drag radials 12.30 1/4 mile 7.82 1/8 mile
Re: Engine Torque Strap??? [Re: 67cuda340] #636667
03/12/10 01:47 AM
03/12/10 01:47 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
A TS on a stick-car ? .. ferr-sure
You can make-one for a 5-spot in 5 minutes.
Re: Engine Torque Strap??? [Re: dOc !] #636668
03/12/10 06:56 AM
03/12/10 06:56 AM
P
P
Thanks guys
Re: Engine Torque Strap??? [Re: Pntastar69] #636669
03/12/10 07:04 PM
03/12/10 07:04 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Definitely on a 4spd car wirh either style mounts and I use one on my 70 Duster 360/904/3.91 combo with early biscuit mounts.
Low buck: Get a $1.69 double hook turnbuckle from Lowes and add a couple links of chain at the top. Drill a hole in the K-frame for the bottom hook and bolt, lock and flatwasher the chain to the drivers side head. Normally a threaded hole there you can use. Tighten the turnbuckle up to your liking.
High buck: Use a Schumacher torque strap which is a good piece.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Engine Torque Strap??? [Re: MY340] #636670
03/12/10 10:43 PM
03/12/10 10:43 PM
scratchnfotraction Offline
I used 2 stock SB tranz to engine struts
cut one end off both struts and welded them together from the bolt hole in the head to the frame on my truck
all mopar and cheap
got that idea from another member here
you can get a spool mount,burn the rubber insert out,weld on 2 big flat washers for end caps and make it a solid mount for one side
like using a solid biscut style on one side
it cut down on vibs from engine to chassis
or run both solid mounts for the max torque limets
Re: Engine Torque Strap??? [Re: scratchnfotraction] #636671
03/13/10 08:47 AM
03/13/10 08:47 AM
London, England
Gavin Offline
Gavin  Offline
London, England
I don't see why you would need a torque strap if you have the spool mounts
Re: Engine Torque Strap??? [Re: Gavin] #636672
03/13/10 08:58 AM
03/13/10 08:58 AM
that rubber rots and sags just like the biskets do over time
I had mine let the engine move almost 2" till the header on the fender well stoped it
i went with the end caps and made it solid on one side
