Brake bleeder #636582
03/11/10 11:19 AM
03/11/10 11:19 AM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Any suggestions on a 1 man brake bleeder system??
Re: Brake bkeeder [Re: Hemiruss] #636583
03/11/10 11:32 AM
03/11/10 11:32 AM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
Your local autozone or napa dealer has a little gadget that will work. It's a plastic cup, with a hose and vent tube that you hook up to the bleeder, then just pump the pedal. There is a more sophisticated (and more $)version that acts like a vacuum pump.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Brake bleeder [Re: Hemiruss] #636584
03/11/10 11:36 AM
03/11/10 11:36 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I like (and use) the Vacula.It works great.
Nautilus Racing-
Re: Brake bleeder [Re: Chris2581] #636585
03/11/10 01:35 PM
03/11/10 01:35 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Sears Crapsman has a light duty and heavy duty version. These are the handheld, had actuated pumps. I bought their light duty one a few years ago and used it a bunch of times. It has finally given out. I am going to probably pick up their better one for $60. I think the last one was $30.
Also do you have a compressor? Those like the Vacula are great if you have a compressor. Those work way better if you have a completely empty system since it needs to move a lot of air and fluid. With the hand pumps, it takes way too much effort to do the same. They might be better for maintenance type bleeding during a brake job or hose replacement than starting from scratch.
I’m interested in what else people are using since I’m in the market for a new one.
Re: Brake bleeder [Re: Hemiruss] #636586
03/11/10 02:23 PM
03/11/10 02:23 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Get these Speed Bleeders from Russell or their generic equivalents from the parts store. Less than $25 for 4, and from there on out you'll only need a tube and cup. They work great.
Re: Brake bleeder [Re: BSharp] #636587
03/11/10 02:37 PM
03/11/10 02:37 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
Same here! These are what I use and they work great!
Re: Brake bleeder [Re: BSharp] #636588
03/11/10 05:13 PM
03/11/10 05:13 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Best invention since toilet paper...
Re: Brake bleeder [Re: Hemiruss] #636589
03/11/10 07:04 PM
03/11/10 07:04 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
I just ordered 2 sets of 5/16" Thanks guys...
Re: Brake bleeder [Re: Hemiruss] #636590
03/11/10 07:17 PM
03/11/10 07:17 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Front disc bleeders are 3/8" IIRC. Rears are 5/16". They don't make the speed bleeders in 5/16"... or if they do, I haven't been able to find them.
Edit: I should say I haven't been able to find them at the parts stores which carry the Dorman "Help!" bleeders.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Brake bleeder [Re: 471Magnum] #636591
03/11/10 07:28 PM
03/11/10 07:28 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Crap I ordered 1/2 of the wrong ones,and Jegs has them under Russell Bleeders(639530 and they showed the same size front&rear...also co.called Speed Bleeders
Re: Brake bleeder [Re: Hemiruss] #636592
03/11/10 07:38 PM
03/11/10 07:38 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I believe they are the same if you've got drums all around, but disc have the bigger size.
The 3/8 ones are available at many discount parts stores in the "Help!" section.
-Jim
Re: Brake bleeder [Re: Hemiruss] #636593
03/11/10 07:51 PM
03/11/10 07:51 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
I just run a hose from the bleeder screw into a mason jar half full of fluid. Open the bleeder screw and pump away. Get out, close the screw and move on the the next one.
Re: Brake bleeder [Re: Leadfoot] #636594
03/11/10 11:48 PM
03/11/10 11:48 PM
BDW Online content
BDW  Online Content
I saved this from a previous post, haven't got around to getting them
For the front Calipers I used P/N 12701. For the rear Drum Brakes I used P/N 12704. My application is a 72 Plymouth Fury Wagon.
These are Dorman PNs you can find in the Help Section (page 5)
http://www.dormanproducts.com/catalog/motormite/008-017_BFinal.pdf
