New gears, do need to replace the lube after break in?
#636436
03/10/10 11:39 PM
03/10/10 11:39 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'm starting out with 2 new gear this year.
Both are race only.
8 3/4 4.30 US Gear with spool in 742 case
Dana 60 4.56 Richmond Pro gears
I've never replaced the lube in the past but I've seen some posts that suggest that I should.
Do you think it's necessary?
If so, could I just suck out some out of the bottom and just replace it.
Or is it a waste of time and money?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: New gears, do need to replace the lube after break in?
[Re: rt66jim]
#636438
03/10/10 11:52 PM
03/10/10 11:52 PM
only if you see metal shavings when draining it out.
[Re: Locomotion]
#636444
03/11/10 12:52 PM
03/11/10 12:52 PM
Posts: 5,080 organ
maximum entropy
organ
i change it after breakin, and annually thereafter. maybe that's why my 8.75 lasted so long before disintegrating?
