New gears, do need to replace the lube after break in? #636436
03/10/10 11:39 PM
03/10/10 11:39 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I'm starting out with 2 new gear this year.
Both are race only.
8 3/4 4.30 US Gear with spool in 742 case
Dana 60 4.56 Richmond Pro gears
I've never replaced the lube in the past but I've seen some posts that suggest that I should.
Do you think it's necessary?
If so, could I just suck out some out of the bottom and just replace it.
Or is it a waste of time and money?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: New gears, do need to replace the lube after break in? [Re: WadeMetzinger] #636437
03/10/10 11:46 PM
03/10/10 11:46 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I hope not. I never did on mine.
Re: New gears, do need to replace the lube after break in? [Re: rt66jim] #636438
03/10/10 11:52 PM
03/10/10 11:52 PM
only if you see metal shavings when draining it out.
Re: New gears, do need to replace the lube after break in? [Re: WadeMetzinger] #636439
03/11/10 12:09 AM
03/11/10 12:09 AM
Mississippi Gulf Coast
Mroctober Offline
Mroctober  Offline
Run it!! waste your time,Save your money, Put that time some where else
Re: New gears, do need to replace the lube after break in? [Re: Mroctober] #636440
03/11/10 11:35 AM
03/11/10 11:35 AM
Joplin, Missouri
Mac's Hemi 64 Offline
Joplin, Missouri
My new Strange says change it after 50 miles but that is with street gears. FWIW
Re: New gears, do need to replace the lube after break in? [Re: Mac's Hemi 64] #636441
03/11/10 11:38 AM
03/11/10 11:38 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
what lube are you guys running in the rear track car
Re: New gears, do need to replace the lube after break in? [Re: earthmover] #636442
03/11/10 11:55 AM
03/11/10 11:55 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I have been running mobile 1 syn 75-90 for 7 years and way over a 1000 passes and hundreds of street miles in mine.
Re: New gears, do need to replace the lube after break in? [Re: WadeMetzinger] #636443
03/11/10 12:49 PM
03/11/10 12:49 PM
Locomotion Offline
Locomotion  Offline
My differential guy said that the coating on the gears is actually abrasive and not good for the bearings. But the amount of it worn off during break-in doesn't necessarily require a lube change. But it doesn't hurt.
I would think that the ideal proceedure would be like for an engine break-in. Break it in with conventional lube then change to synthetic. It's a pain to change just for the sake of changing the fluid, but my next housing will have a drain plug with a magnet.
I use Amsoil Severe Gear 75W-90.
Re: New gears, do need to replace the lube after break in? [Re: Locomotion] #636444
03/11/10 12:52 PM
03/11/10 12:52 PM
organ
maximum entropy Offline
organ
i change it after breakin, and annually thereafter. maybe that's why my 8.75 lasted so long before disintegrating?
