Re: Fuse box help!
[Re: polkat]
#63614
05/26/08 12:31 PM
05/26/08 12:31 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Dunno the year we are talking BUT only spade terminals should arrive to back of fuse box should it be with RED wire to the Batt buss bar ( devices feeded directly from batt/alt, and not ign key ) and BLACK wire, being the ACC buss bar, and comes from ignition switch to feed accesories.
both are as far I remember 12 gauge
So probably you unplugged that wire.
you can check if you have power there constant or just when put the ign key on accesories position
Re: Fuse box help!
[Re: polkat]
#63616
05/26/08 12:40 PM
05/26/08 12:40 PM
NachoRT74
Valencia, España
well thats easy... if you have TWO buss bars, both must have a wire to get power. If not, then you have a fuses side getting not juice
