Fuse box help! #63611
05/26/08 03:01 AM
05/26/08 03:01 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I pulled the instrument cluster to replace the bulbs and noticed a heavy guage black wire attached by a spade connector to the back of the fuse box (opposite the side where the fuses are). It is disconnect, and I don't know if I accidently disconnected it while pulling the dash or not (looks like someone might have pulled it years ago). I can't seem to trace where it goes. Does anyone know what this wire is/does, and should I hook it back up?
Thanks!
Re: Fuse box help! [Re: polkat] #63612
05/26/08 10:22 AM
05/26/08 10:22 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check for two wires on the amp gauge.
Re: Fuse box help! [Re: stumpy] #63613
05/26/08 12:13 PM
05/26/08 12:13 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Okay, I'll try tracing that back to the gauge. Any other ideas?
Re: Fuse box help! [Re: polkat] #63614
05/26/08 12:31 PM
05/26/08 12:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Dunno the year we are talking BUT only spade terminals should arrive to back of fuse box should it be with RED wire to the Batt buss bar ( devices feeded directly from batt/alt, and not ign key ) and BLACK wire, being the ACC buss bar, and comes from ignition switch to feed accesories.
both are as far I remember 12 gauge
So probably you unplugged that wire.
you can check if you have power there constant or just when put the ign key on accesories position
Re: Fuse box help! [Re: NachoRT74] #63615
05/26/08 12:34 PM
05/26/08 12:34 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Thanks! I'll plug it back in and see what happens.
Re: Fuse box help! [Re: polkat] #63616
05/26/08 12:40 PM
05/26/08 12:40 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well thats easy... if you have TWO buss bars, both must have a wire to get power. If not, then you have a fuses side getting not juice
