I need a cram course on BB Darts. (20 questions)
#635834
03/10/10 05:42 PM
03/10/10 05:42 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
...and I have A.D.D. The best wey to get the exact info I need on some very specific issues is to play twenty questions. Here's the first: The factory never offered nor make a 440 Dart. (T) (F)?
Re: I need a cram course on BB Darts. (20 questions)
[Re: Commando1]
#635837
03/10/10 06:04 PM
03/10/10 06:04 PM
Posts: 4,978 VA
DAMOPARS
VA
[Re: Sasquatch4406]
#635840
03/10/10 07:02 PM
03/10/10 07:02 PM
RapidRobert
I dont have that kind of patience. Put the rest of the 20 Q's in one post (numbered & in order of importance to you )
[Re: Jim_Lusk]
#635843
03/10/10 09:12 PM
03/10/10 09:12 PM
Commando1
1968 Grand Spaulding only (I think) built at the Hurst plant 1969 ANY dealer, Chrysler factory built
1968 GSS badges 1969 GTS badges
OK. 1969. Dart GTS; factory built 440. Got it. Was PS, PDB, and A/C available? Plus, I'm looking *HERE* and don't see anything about a 440 being available. Anywhere else I can look?
Here. I'll elliminate 3 - 20 with one question: I need all the specs possible for a 1969 GTS 440 4 speed. Options, codes, deletes, stand. equipt., #'s, blah blah blah. If it's relevant, I'm interested...
2. What's the capital of Nebraska?
You! Stay after school for disrupting the class...
[Re: Commando1]
#635844
03/10/10 10:11 PM
03/10/10 10:11 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
A very long while back, in about 1982 I looked at a few M code 1969 Darts for sale. Larry Sheppard of Chrysler told me he was thinking Chrysler made about 200 of them. I found out later that only 1 "M" Code Dart was sold new in Canada and 4 "M" Code Barracudas were sold new in Canada along with plenty in the USA. If you would like to know a lot more there are "A" Body sites and Darts sites that can give good answer if the answer on Moparts are not enough.
1971 HEMI E BODY REGISTRY
[Re: 383man]
#635849
03/11/10 07:46 AM
03/11/10 07:46 AM
Posts: 601 Mass
charge70
Mass
All 69 M-Code cars were built right on the Chrysler Assy. line not at Hurst. They were all floor shift automatics,manual drum brakes,and rear end gears of either 3:55 or 3:91. A.C.,power steering,power brakes or disc brakes were not available options.They all have rear spring front welded torque boxes,like a drop top has. Also on the data plate,cars with SBD before 329 will have either A13 or Y39 called out,but not both.I don't remember which one.After that date,the tag will have both. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: Commando1]
#635851
03/11/10 10:14 AM
03/11/10 10:14 AM
Posts: 601 Mass
charge70
Mass
Left side is M-Code only,good luck finding that one,BIG $$$.Right side is the same as 383 A-body,but with a 3/4" spacer added onto the bottom to space the pipe down away from the body.I think someone was talking about repoping this spacer,not sure if it available yet. Also the L/F motor mount bracket is unique to M-Code only. John.
