'68 Satellite transmission fluid #635547
03/10/10 08:42 AM
03/10/10 08:42 AM
SE Louisiana
Tdog1 Offline OP
Tdog1  Offline OP
SE Louisiana
I have a '68 satellite & need to add transmission fluid. I have Dextron III on hand, but I'm sure that was not available when the car was made. Is it OK to use? If not, what is recommended?
I'm not a mechanic!
Thanks,
Jack
Re: '68 Satellite transmission fluid [Re: Tdog1] #635548
03/10/10 09:56 AM
03/10/10 09:56 AM
PA
70Duster Offline
70Duster  Offline
PA
Dexron III is fine. Go ahead and use it.
Re: '68 Satellite transmission fluid [Re: 70Duster] #635549
03/10/10 10:53 AM
03/10/10 10:53 AM
SE Louisiana
Tdog1 Offline OP
Tdog1  Offline OP
SE Louisiana
thanx
Re: '68 Satellite transmission fluid [Re: Tdog1] #635550
03/10/10 12:41 PM
03/10/10 12:41 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Someone mentioned 3M adhesive remover. Although it worked well for what I needed (removal of excess weatherstrip glue), I think it's only a small step up from Goo Gone.
Re: '68 Satellite transmission fluid [Re: HitIt] #635551
03/10/10 01:35 PM
03/10/10 01:35 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
huh
Re: '68 Satellite transmission fluid [Re: HitIt] #635552
03/10/10 03:49 PM
03/10/10 03:49 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Caution.....forementioned product contains substances known to cause Hallucinations.
Re: '68 Satellite transmission fluid [Re: HitIt] #635553
03/10/10 05:43 PM
03/10/10 05:43 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
WOULDNT USE IT AS A TRANNY FUILD.
Re: '68 Satellite transmission fluid [Re: 05dakota] #635554
03/10/10 05:57 PM
03/10/10 05:57 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
He was obviously trying to respond to a different thread. I hope . By the way Dexron III is fine.
