73-76 A-Body Spool Mount K-Frame, Pros/Cons #63483
05/25/08 09:12 PM
05/25/08 09:12 PM
Pittsburgh, PA
W
wayfarer1 Offline OP
W
Pittsburgh, PA
I am in the process of pulling the junk 318 and 904 from my 72 Swinger to start the resto. I can see evidence of some pretty heave pitting and surface rust on the stock V8 K-frame. I am thinking about replacing it and I know where there are 2 spool type k-frames, one has a complete disc brake setup on it.
My question is what are the benefits of the spool k-frame over the earlier biscuit type and are there and problems with the newer design that I should be concerned with.
Any help will be appreciated,
Joe
Current Project: 72 Roadrunner 340/727/Petty Blue/White Roof Strobe Stripe/Black Bucket Interior
71 Demon project
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: wayfarer1] #63484
05/25/08 09:43 PM
05/25/08 09:43 PM
In a van, down by the river
jmf340 Offline
jmf340  Offline
I don't know about any design flaws or benefits to the newer style spool mount, other than I feel it is easier to get the motor mount in the desired frame mount and slide a bolt through. It also tells you that the motor is situated correctly. Just my opinion though.
Got Mopar???
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: jmf340] #63485
05/25/08 09:46 PM
05/25/08 09:46 PM
spool mount are superior in everyway.
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons #63486
05/25/08 10:16 PM
05/25/08 10:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: autoxcuda] #63487
05/26/08 08:04 AM
05/26/08 08:04 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
only negative is I think the front track on the later big-bolt pattern K's are a little wider...
2017 Grand Cherokee Overland
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: patrick] #63488
05/26/08 02:24 PM
05/26/08 02:24 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
I think thats due to the spindle/rotor. The LCAs are the same.
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: patrick] #63489
05/26/08 03:15 PM
05/26/08 03:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Like Rocketride said, thats from the spindles/rotors. So if you do the factory type BBP conversion to a 67-72 A-body, you be at the same width.
I had the BBP conversion in my 68 K-member. Then I switched to just the 73-76 K-member. No width change and no engine height change either.
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: autoxcuda] #63490
05/26/08 08:26 PM
05/26/08 08:26 PM
Pittsburgh, PA
W
W
Pittsburgh, PA
So if I use the BBP disc brakes I have with the 73 spool k-member I should be good?
I have to get the old motor out first and evaluate the condition of the original k-frame before I make a final decision on replacing it.
Thanks for the info!
Joe
71 Demon project
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: wayfarer1] #63491
05/26/08 08:56 PM
05/26/08 08:56 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Joe
Yes, that will be fine. If have to, you can re-use your 72 biscuit type K-member too.
Do any of these setups have lower control arms with sway bars tabs??
The one on the left is a 73-76. The one of the right is a 67-72
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: autoxcuda] #63492
05/27/08 09:13 AM
05/27/08 09:13 AM
Pittsburgh, PA
W
W
Pittsburgh, PA
I doubt it. The complete 73 Dart Swinger in the yard is just a 318 car with A/C and the other 73 is a 4 door and has been stripped pretty good but the K-Member is still there.
However, if there happens to be a a swaybar setup, you can gaurantee it will find its way onto my car!
Joe
71 Demon project
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: wayfarer1] #63493
05/28/08 09:47 PM
05/28/08 09:47 PM
Hesston, KS
boden Offline
boden  Offline
Hesston, KS
One con is that to you cannot install a 5.7 hemi with the TTI brackets using spool mounts. I actually cut 2 k-frames apart and made a hybrid. Top half is 72- for engine mounts, bottom half is 73+ style for the throught the k-frame sway bar.
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: boden] #63494
05/28/08 10:04 PM
05/28/08 10:04 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
you can buy a sway bar kit. another great thing about the spool mount is the sway bar goes through the k and doesn't hang below. also your not going to pull a motor mount apart.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: 65cuda] #63495
05/28/08 10:17 PM
05/28/08 10:17 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: boden] #63496
05/28/08 11:14 PM
05/28/08 11:14 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: RokketRide] #63497
05/29/08 12:21 AM
05/29/08 12:21 AM
Pittsburgh, PA
W
W
Pittsburgh, PA
Well, I found out today that a friend has a spool mount k-frame that I will be buying from him for a good price. He does not have the mounting brackets though. I know where there are 2 V8 Darts with the brackets still attached.
Is there an easy way to remove the mounting brackets with the engine still in the car or will I have to have the motor pulled to get them off?
Thanks to all for the great info!
71 Demon project
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: wayfarer1] #63498
05/29/08 12:34 AM
05/29/08 12:34 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i got mine from advance auto parts. new and ready to bolt in.
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: 65cuda] #63499
05/29/08 12:45 AM
05/29/08 12:45 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, spool mount motor mounts have the motor mount brackets integrated with them.
The long bolt that goes through the motor mount and to the K-member is sort of special. The washer fit the k-frame and IIRC, it's swaged in the center so it doesn't spin when you tighten it??
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: autoxcuda] #63500
05/29/08 12:50 AM
05/29/08 12:50 AM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Crap, I gotta find a set of those, my parts car didnt have them.
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: autoxcuda] #63501
05/29/08 12:50 AM
05/29/08 12:50 AM
sounds bout right.
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: RokketRide] #63502
05/29/08 01:56 AM
05/29/08 01:56 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Might be available from dealer.
Same as any junkyard FMJ and R-body bolt. Maybe even others.
