edlebrock 800 cfm thunder series opinions....
#634413
03/08/10 08:30 PM
03/08/10 08:30 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Does anyone have an opinion on Edlebrock's 800 cfm Thunder series carbs. How are they to work with? Do people have issues with them? Any knowledge would be great
Mike
1969 Dodge Dart Swinger
Re: edlebrock 800 cfm thunder series opinions....
[Re: RemCharger]
#634415
03/08/10 09:01 PM
03/08/10 09:01 PM
i run them and love em. dual quads, very easy to tune to.
[Re: AndyF]
#634417
03/08/10 11:52 PM
03/08/10 11:52 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
We use two of them on an Indy intake, with a Indy headed NSS motor.
They are great!!! Easy to work with....once that big plenum heats up you could idle through a McD's drive through.
Can't beat them.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Steve1118]
#634418
03/09/10 06:03 AM
03/09/10 06:03 AM
Yep, they work great......much better fuel curve than the Edlebrock Performer carbs.......
Did you ever get a good converter in your car?
Wayne
#634419
03/09/10 07:38 AM
03/09/10 07:38 AM
The 800 even works great on milder street engines believe it or not--I love them--I only use the Thunder series --the std 750 is a pain and must have some design problem--they can be a nightmare but the 800 Thunder series is fantastic for the $$ Best Holley out there IMO is the 750 HP body by AED in Richmond Va for the $$ one of the best--if you have enough initial timing at idle they are amazing! Customer service is great too. I use about one a week of these two so ...
[Re: ]
#634420
03/09/10 07:59 AM
03/09/10 07:59 AM
Posts: 1,051 The Great White North
RAMM
Thunder series AVS carbs are quite good. Smooth, great idle, easy to tune. I have used them on smallblocks big blocks and even Chevys. Thanks J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: Mr.Yuck]
#634422
03/09/10 03:10 PM
03/09/10 03:10 PM
you'll need two in order to beat one holley.
Maybe if you're tuning on them......
Wayne
#634423
03/09/10 03:25 PM
03/09/10 03:25 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Wayne
humm 3 big block posters use them in pairs....not saying an 800 eddy is junk, just not as good as a 750 Holley.
[Re: 9SecRoadRunner]
#634425
03/09/10 03:54 PM
03/09/10 03:54 PM
Mr.Yuck
Brookeville, Md
Wayne
any dyno PROOF to back up that claim?
just the one I sit on. swapped a few 750 eddy;s for 750 DP's and the DP was much better even w/o much tuning.
#634426
03/09/10 05:27 PM
03/09/10 05:27 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Wayne
I'm at a lot of drag strips and I don't see them on anything other than mild street/strip combos.
[Re: BobR]
#634427
03/09/10 05:37 PM
03/09/10 05:37 PM
Quicktree
Wayne
theres a reason for that, they are street carbs.
[Re: BobR]
#634428
03/09/10 05:53 PM
03/09/10 05:53 PM
I'm at a lot of drag strips and I hardly see any Mopars, so they must all be mild street/strip cars.......
Point is; For the original poster, YES , they work great for a relatively mild street/strip car and YES, they are a lot better than the RPM carbs.......whereas a Holley is infinitely tuneable so you can tune around 90% of people's messed up combo's.......An Edelbrock, typically, needs a fairly good amount of vacuum to work good......and the Thunder Series is nice because you can slow down the secondary opening so it won't bog if you do have a motor with fairly low vacuum.......
Wayne
[Re: sasquatch]
#634431
03/09/10 07:55 PM
03/09/10 07:55 PM
Quicktree
Gee I have a customer that has a pair of the 800 AVS carbs on a Stage V inline intake and fairly mild hemi that only made 845 on the pump and runs 9.50s at close to 3600 lbs. No gurus, no secret voodoo magic, out of the box and we changed the jets a little. Just junky street carbs though. Alot of the NSS guys run them on the wedges and the hemis due to class rules and they crack off plenty of 9 second passes all the time. Todd.
and the FAST cars about to catch them on bias ply street tires
