edlebrock 800 cfm thunder series opinions.... #634413
03/08/10 08:30 PM
03/08/10 08:30 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Does anyone have an opinion on Edlebrock's 800 cfm Thunder series carbs. How are they to work with? Do people have issues with them? Any knowledge would be great
Mike
1969 Dodge Dart Swinger
Re: edlebrock 800 cfm thunder series opinions.... [Re: MikeyT] #634414
03/08/10 08:46 PM
03/08/10 08:46 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Can't remember the last time I saw an el-dabrock/carter at the dragstrip..
What do you want it to do? (more info)
Re: edlebrock 800 cfm thunder series opinions.... [Re: RemCharger] #634415
03/08/10 09:01 PM
03/08/10 09:01 PM
i run them and love em. dual quads, very easy to tune to.
Re: edlebrock 800 cfm thunder series opinions.... [Re: MikeyT] #634416
03/08/10 10:27 PM
03/08/10 10:27 PM
AndyF Offline
AndyF  Offline
Those carbs work great. I've used a bunch of them over the years on various combinations. Very nice carb for dual quad applications but they also work great on a Performer RPM or even single plane intakes.
Re: edlebrock 800 cfm thunder series opinions.... [Re: AndyF] #634417
03/08/10 11:52 PM
03/08/10 11:52 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
We use two of them on an Indy intake, with a Indy headed NSS motor.
They are great!!! Easy to work with....once that big plenum heats up you could idle through a McD's drive through.
Can't beat them.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: edlebrock 800 cfm thunder series opinions.... [Re: Steve1118] #634418
03/09/10 06:03 AM
03/09/10 06:03 AM
Yep, they work great......much better fuel curve than the Edlebrock Performer carbs.......
Did you ever get a good converter in your car?
Wayne
Re: edlebrock 800 cfm thunder series opinions.... #634419
03/09/10 07:38 AM
03/09/10 07:38 AM
The 800 even works great on milder street engines believe it or not--I love them--I only use the Thunder series --the std 750 is a pain and must have some design problem--they can be a nightmare but the 800 Thunder series is fantastic for the $$
Best Holley out there IMO is the 750 HP body by AED in Richmond Va for the $$ one of the best--if you have enough initial timing at idle they are amazing! Customer service is great too.
I use about one a week of these two so ...
Re: edlebrock 800 cfm thunder series opinions.... [Re: ] #634420
03/09/10 07:59 AM
03/09/10 07:59 AM
The Great White North
RAMM Offline
RAMM  Offline
Thunder series AVS carbs are quite good. Smooth, great idle, easy to tune. I have used them on smallblocks big blocks and even Chevys. Thanks J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: edlebrock 800 cfm thunder series opinions.... [Re: ] #634421
03/09/10 09:53 AM
03/09/10 09:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'll need two in order to beat one holley.
Coming soon!!!!
Re: edlebrock 800 cfm thunder series opinions.... [Re: Mr.Yuck] #634422
03/09/10 03:10 PM
03/09/10 03:10 PM
Maybe if you're tuning on them......
Wayne
Re: edlebrock 800 cfm thunder series opinions.... #634423
03/09/10 03:25 PM
03/09/10 03:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Wayne
humm 3 big block posters use them in pairs....not saying an 800 eddy is junk, just not as good as a 750 Holley.
Re: edlebrock 800 cfm thunder series opinions.... [Re: Mr.Yuck] #634424
03/09/10 03:46 PM
03/09/10 03:46 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
Wayne
any dyno PROOF to back up that claim?
You Thinking It's So Doesn't Make It a Fact
Re: edlebrock 800 cfm thunder series opinions.... [Re: 9SecRoadRunner] #634425
03/09/10 03:54 PM
03/09/10 03:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Wayne
just the one I sit on. swapped a few 750 eddy;s for 750 DP's and the DP was much better even w/o much tuning.
Re: edlebrock 800 cfm thunder series opinions.... [Re: 9SecRoadRunner] #634426
03/09/10 05:27 PM
03/09/10 05:27 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Wayne
I'm at a lot of drag strips and I don't see them on anything other than mild street/strip combos.
Re: edlebrock 800 cfm thunder series opinions.... [Re: BobR] #634427
03/09/10 05:37 PM
03/09/10 05:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Wayne
theres a reason for that, they are street carbs.
Re: edlebrock 800 cfm thunder series opinions.... [Re: BobR] #634428
03/09/10 05:53 PM
03/09/10 05:53 PM
I'm at a lot of drag strips and I hardly see any Mopars, so they must all be mild street/strip cars.......
Point is; For the original poster, YES , they work great for a relatively mild street/strip car and YES, they are a lot better than the RPM carbs.......whereas a Holley is infinitely tuneable so you can tune around 90% of people's messed up combo's.......An Edelbrock, typically, needs a fairly good amount of vacuum to work good......and the Thunder Series is nice because you can slow down the secondary opening so it won't bog if you do have a motor with fairly low vacuum.......
Wayne
Re: edlebrock 800 cfm thunder series opinions.... [Re: ] #634429
03/09/10 06:51 PM
03/09/10 06:51 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
aed is all i use too.awesome stuff for the $$$
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: edlebrock 800 cfm thunder series opinions.... [Re: Old School] #634430
03/09/10 07:04 PM
03/09/10 07:04 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Gee I have a customer that has a pair of the 800 AVS carbs on a Stage V inline intake and fairly mild hemi that only made 845 on the pump and runs 9.50s at close to 3600 lbs. No gurus, no secret voodoo magic, out of the box and we changed the jets a little. Just junky street carbs though. Alot of the NSS guys run them on the wedges and the hemis due to class rules and they crack off plenty of 9 second passes all the time.
Todd.
Re: edlebrock 800 cfm thunder series opinions.... [Re: sasquatch] #634431
03/09/10 07:55 PM
03/09/10 07:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Todd.
and the FAST cars about to catch them on bias ply street tires
Re: edlebrock 800 cfm thunder series opinions.... [Re: Quicktree] #634432
03/09/10 08:28 PM
03/09/10 08:28 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I have one on my 427" SBF and I'm really happy with it, the only changes from OOTB is I needed to go to a dual line feed and I fattened the mid range up by using the stiffer step-up springs (which takes about 2 minutes) to bring the primary main jets in quicker (which in turn boosts the signal strength to the secondary air door). Tweaking becomes second-nature once you get used to them and I've actually tweaked AVS's to run as quick or quicker than Holleys with better off idle response and better overall drivability.
For high stall converters and especially WOT it's tough to beat a well tuned holley, but to me it's really more about secondary shooter tuning than anything else, jetting and power output can be very close in the hands of a good tuner for comparably sized carbs.
The eddy AVS is very responsive off idle and much more tractible (coming off sharp corners....the reason I ditched the double pumper) in a 500+ horse 2450 pound car that gets driven hard everywhere.
I like them, I always had very good results with the AVS type carbs (including the TQ).
WIZE
In Car:
