six pak dumping gas #634234
03/08/10 06:21 PM
03/08/10 06:21 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Started car up sunday heard gas dumping like a water facet running in rear carb.Brought billet rear plate from promax saturday was going to change it out sunday.Any ideai on why gas was dumping in rear carb.Last started car in oct everything was okay.
Re: six pak dumping gas [Re: gtx69] #634235
03/08/10 06:25 PM
03/08/10 06:25 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
did you change the plate? i heard something about the floats can hit the jets if a certain float is in there. I have brass floats i believe and mine didnt hit.
if you didnt put the plate in yet, then its a stuck needle valve. probably got junk in it
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: six pak dumping gas [Re: aarcuda] #634236
03/08/10 07:23 PM
03/08/10 07:23 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Never changed anything.Happened before i took it off to change.
Re: six pak dumping gas [Re: aarcuda] #634237
03/08/10 08:35 PM
03/08/10 08:35 PM
pull the needle/seat assy & check it & might replace it.
Re: six pak dumping gas [Re: gtx69] #634238
03/08/10 08:40 PM
03/08/10 08:40 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Check the o-ring on that needle and seat, my sixpack car sits for a long time and that o-ring dries out and fuel pours out of the vent tube.
Re: six pak dumping gas [Re: RV2] #634239
03/09/10 08:16 PM
03/09/10 08:16 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I have had to pull mine out a couple times because of fuel coming out of the ventury tube.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: six pak dumping gas [Re: 70sixpkrt] #634240
03/09/10 08:34 PM
03/09/10 08:34 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I used to have a problem with fuel flooding in when I was using 50/50 mix AV gas.
I'd leave the car sit for a couple of months , and just by hitting the fuel pump switch I could tell it was flooding.
Did two things...STOPPED using AV gas in any dilution, and changed to different needles.
No more problems. I still think the AV gas had something to do with it.
I can't find the part #'s for the needles, but they were Holley High Flows.
Re: six pak dumping gas [Re: superwrench] #634241
03/09/10 08:35 PM
03/09/10 08:35 PM
70sixpkrt Offline
70sixpkrt  Offline
If you find the part #'s, can you post them?
4-speed
3:54 Dana
Re: six pak dumping gas [Re: 70sixpkrt] #634242
03/09/10 09:49 PM
03/09/10 09:49 PM
Proud South
a440plus6 Offline
a440plus6  Offline
Proud South
Sounds like stuck float to me.
Whack it on top of the bowl with a rubber mallet is easiest way to check.
Center carb has Brass float and outboards have some kinda plastic...Polypropylene or something....they are NOT interchangeable....they will rub on the inside of the bowl and hang up.
