Sounds like stuck float to me.
Whack it on top of the bowl with a rubber mallet is easiest way to check.
Center carb has Brass float and outboards have some kinda plastic...Polypropylene or something....they are NOT interchangeable....they will rub on the inside of the bowl and hang up.
