cuda tail light panel black paint question #633910
03/08/10 10:35 AM
03/08/10 10:35 AM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
currently my 74 barracuda rear panel is painted red matching the body. i would like to paint it black and was wondering what would be the best color,brand and procedure to do this using sray bombs until i can get the car repainted in a few years?
Re: cuda tail light panel black paint question [Re: jbcuda] #633911
03/08/10 11:30 AM
03/08/10 11:30 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Spray bomb route ??? That's an easy one...Get Krylon semi-gloss black...Walmart carries it...Tape off the tailpanel and shoot a good coverage coat or two...Then stand back and mist coat to add some texture....The nice thing about the krylon is it will cover without lifting the paint and you can touch-up any time if need be without the issues other bombs have...
Re: cuda tail light panel black paint question [Re: screamindriver] #633912
03/08/10 01:19 PM
03/08/10 01:19 PM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
sounds good to me thanks!
Re: cuda tail light panel black paint question [Re: jbcuda] #633913
03/08/10 02:19 PM
03/08/10 02:19 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
DP90 Black epoxy primer.
Re: cuda tail light panel black paint question [Re: jbcuda] #633914
03/08/10 08:47 PM
03/08/10 08:47 PM
CT
3
340KID Offline
340KID  Offline
CT
I used rustoleum black textured paint, laid down real nice - did a couple of coats and it came out perfect.
Re: cuda tail light panel black paint question [Re: 340KID] #633915
03/09/10 09:24 AM
03/09/10 09:24 AM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
how did you prep the panel before paint? looks great!
Re: cuda tail light panel black paint question [Re: jbcuda] #633916
03/09/10 10:11 AM
03/09/10 10:11 AM
PA USA
ScatPakWarehouse Offline
Good Guy Alert
Good Guy Alert
PA USA
Spray bomb route ??? That's an easy one...Get Krylon semi-gloss black...Walmart carries it...Tape off the tailpanel and shoot a good coverage coat or two...Then stand back and mist coat to add some texture....The nice thing about the krylon is it will cover without lifting the paint and you can touch-up any time if need be without the issues other bombs have... Did this 28 years ago still looks great ... Sorry no pics
Re: cuda tail light panel black paint question [Re: jbcuda] #633917
03/09/10 11:29 PM
03/09/10 11:29 PM
CT
3
340KID Offline
340KID  Offline
CT
when i had the car painted, the shop sprayed it in base/clear (black with a flattening agent) and it came out glossy, it did not look good, so i scuffed it and shot it with the texture spray bomb, did the panel and the spoiler, it looks a little glossy in this pic but it is not, it has a nice fine texture and looks real good, it's almost like a black argent.
