Re: long rod vs short rod?
[Re: griff70440]
#633298
03/07/10 10:22 PM
03/07/10 10:22 PM
Nope, not worth it.....it's like peeing in the ocean to raise the tide.......not even noticeable.......The rod just connects the piston to the crank........ Wayne
#633299
03/08/10 12:27 AM
03/08/10 12:27 AM
Posts: 4,209 New York
polyspheric
New York
And there are a large number of people, including me, who hold the opposite opinion. This group also includes all auto, airplane, motorcycle, diesel and tractor engine manufacturers and builders for the last 100 years.
Your choice.
Boffin Emeritus
[Re: polyspheric]
#633300
03/08/10 12:39 AM
03/08/10 12:39 AM
Your choice.
Opinion is one thing, facts are another.....
Show me some actual dyno numbers that actually amount to anything that would be enough to change the MPH of a 3,700LB car at the drag strip.........I'll be holding my breath......
Are YOU saying the OP is going to see a power gain by swapping rods and pistons, while keeping EVERYTHING else equal???
Wayne
#633301
03/08/10 12:53 AM
03/08/10 12:53 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Your choice.
Wayne
Wayne, Start Breathing...
Be spending allot of money for no measurable change
[Re: 1_WILD_RT]
#633303
03/08/10 08:35 AM
03/08/10 08:35 AM
Your choice.
Wayne
Yeah, I'm the little blue guy in Oklahoma......
Wayne
#633304
03/08/10 10:26 AM
03/08/10 10:26 AM
polyspheric
New York
Great answer. I'd explain, but you're already too smart.
Boffin Emeritus
#633305
03/08/10 11:14 AM
03/08/10 11:14 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i wont argue if the change should be made.. or if in this situation it will mean much difference in output.
however to ignore the elephant in the room..(ie;whats the differnce in rod length matter?)
i would direct the attention to the port volume of the head and the cam being used..
a longer rod..as a matter of fact...gives more piston dwell..at top and bottom.
if the intake port volume has a smaller ratio to cubic inces.(lacking sufficient port volume) then the longer rod and the right cam event timing..could produce more power.. understanding/knowing this can make a difference. Imho. combustion chamber efficiencies will also factor. so it WOULD be relevant...atleast for arguement sake.. again..it may not be relevant in this motor.. but theoretically its relevant.
it would factor in when starting from a clean sheet of paper and what approach you want to take. again..fwiw.
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: emarine01]
#633307
03/08/10 12:49 PM
03/08/10 12:49 PM
Power gain is not the only way to look at this question, what about failure rate and longevity,
The OP asked if there are any horse power gains......and this isn't a Comp Eliminator motor.......
Wayne
#633309
03/08/10 01:00 PM
03/08/10 01:00 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Don't worry about the rod length, just pick a piston that is the most stable for the rings for good seal and long life for your app. The 6.535 length is just fine. Roughly a 1.3 pin height is great as well. Lots of guys are running that setup with excellent results. 440Jim is an excellent example. Not many are as fast as his car running similar cams,heads,etc. You can engineer something to the Nth degree, for a very small return, or you can not worry about whether you got that 1 or 2 hp and spend the money racing.
Post deleted by Defbob
[Re: polyspheric]
#633311
03/08/10 01:30 PM
03/08/10 01:30 PM
#633313
03/08/10 02:39 PM
03/08/10 02:39 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Wayne
PERFECT analogy!
