Page 1 of 3 1 2 3
long rod vs short rod? #633297
03/07/10 09:08 PM
03/07/10 09:08 PM
griff70440 Offline OP
Hi
I have a 6.535 rod in my 511 and its time to re ring and put new bearings in the motor.
my question is would it be worth it to change the rod to a longer one?any HP gains?(I know I have to change the pistons too)
this is my combo now
400 stroked to 511
345-1`s jesel rockers and belt drive
mid 7`s roller
14-1 compression(ross pistons)
tunnel ram w/2-1050`s
rod lenght(6.535)
thanks mike
Re: long rod vs short rod? [Re: griff70440] #633298
03/07/10 10:22 PM
03/07/10 10:22 PM
Nope, not worth it.....it's like peeing in the ocean to raise the tide.......not even noticeable.......The rod just connects the piston to the crank........
Wayne
Re: long rod vs short rod? #633299
03/08/10 12:27 AM
03/08/10 12:27 AM
New York
polyspheric Offline
polyspheric  Offline
New York
And there are a large number of people, including me, who hold the opposite opinion.
This group also includes all auto, airplane, motorcycle, diesel and tractor engine manufacturers and builders for the last 100 years.
Your choice.
Boffin Emeritus
Re: long rod vs short rod? [Re: polyspheric] #633300
03/08/10 12:39 AM
03/08/10 12:39 AM
Your choice.
Opinion is one thing, facts are another.....
Show me some actual dyno numbers that actually amount to anything that would be enough to change the MPH of a 3,700LB car at the drag strip.........I'll be holding my breath......
Are YOU saying the OP is going to see a power gain by swapping rods and pistons, while keeping EVERYTHING else equal???
Wayne
Re: long rod vs short rod? #633301
03/08/10 12:53 AM
03/08/10 12:53 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Your choice.
Wayne
Wayne, Start Breathing...
Be spending allot of money for no measurable change
Re: long rod vs short rod? [Re: 1_WILD_RT] #633302
03/08/10 06:33 AM
03/08/10 06:33 AM
UK
602heavy Offline
602heavy  Offline
UK
Long rod/short rod both have their advantages/disadvantages , in my view comp height would be the deciding factor on rod length , more so when using power adders , i would always lean towards a long rod over the short one due to side loading , lots of opinions on this although no real performance gain when using either rod.
Ever been asked rod length when having a cam speced for you're motor?...............
Re: long rod vs short rod? [Re: 1_WILD_RT] #633303
03/08/10 08:35 AM
03/08/10 08:35 AM
Your choice.
Wayne
Yeah, I'm the little blue guy in Oklahoma......
Wayne
Re: long rod vs short rod? #633304
03/08/10 10:26 AM
03/08/10 10:26 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Great answer.
I'd explain, but you're already too smart.
Boffin Emeritus
Re: long rod vs short rod? #633305
03/08/10 11:14 AM
03/08/10 11:14 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i wont argue if the change should be made..
or if in this situation it will mean much difference in output.
however to ignore the elephant in the room..(ie;whats the differnce in rod length matter?)
i would direct the attention to the port volume of the head and the cam being used..
a longer rod..as a matter of fact...gives more piston dwell..at top and bottom.
if the intake port volume has a smaller ratio to cubic inces.(lacking sufficient port volume)
then the longer rod and the right cam event timing..could produce more power..
understanding/knowing this can make a difference. Imho.
combustion chamber efficiencies will also factor.
so it WOULD be relevant...atleast for arguement sake..
again..it may not be relevant in this motor..
but theoretically its relevant.
it would factor in when starting from a clean sheet of paper and what approach you want to take.
again..fwiw.
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: long rod vs short rod? [Re: cheapstreetdustr] #633306
03/08/10 12:24 PM
03/08/10 12:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Power gain is not the only way to look at this question, what about failure rate and longevity,
Re: long rod vs short rod? [Re: emarine01] #633307
03/08/10 12:49 PM
03/08/10 12:49 PM
The OP asked if there are any horse power gains......and this isn't a Comp Eliminator motor.......
Wayne
Re: long rod vs short rod? #633308
03/08/10 12:54 PM
03/08/10 12:54 PM
Wayne
Understood...
cheapst
[image][/image]
Re: long rod vs short rod? #633309
03/08/10 01:00 PM
03/08/10 01:00 PM
gregsdart Offline
gregsdart  Offline
Don't worry about the rod length, just pick a piston that is the most stable for the rings for good seal and long life for your app. The 6.535 length is just fine. Roughly a 1.3 pin height is great as well.
Lots of guys are running that setup with excellent results. 440Jim is an excellent example. Not many are as fast as his car running similar cams,heads,etc.
You can engineer something to the Nth degree, for a very small return, or you can not worry about whether you got that 1 or 2 hp and spend the money racing.
Re: long rod vs short rod? [Re: cheapstreetdustr] #633310
03/08/10 01:01 PM
03/08/10 01:01 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Ok I see your point, From what I have read there is a small power gain on the long rod but it would not be cost effective to change an existing set up unless money was no problem, Something to be considered @ the planning of a new build
Post deleted by Defbob [Re: polyspheric] #633311
03/08/10 01:30 PM
03/08/10 01:30 PM
Re: long rod vs short rod? #633312
03/08/10 01:43 PM
03/08/10 01:43 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
There is something to be said for skirt loading, dwell time and a few other things, but in the big picture, the rod connects the piston to the crank and thats it. Most high end motors, do tend to stuff as much rod in as possible, but that is as much about weight as anything. A .100 on rod length is a good deal less weight than a piston with a .100 more compression distance. Also boils down to intent and purpose of the motor. As said, the original poster asked about his combo in particular...so will a longer rod give him more power...NO
Monte
Re: long rod vs short rod? #633313
03/08/10 02:39 PM
03/08/10 02:39 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Wayne
PERFECT analogy!
Re: long rod vs short rod? [Re: BobR] #633314
03/08/10 03:27 PM
03/08/10 03:27 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Our 500 with 6.535 rods made 845 hp with single carb on gas. Simple build. I don't think a longer or shorter rod would have made much difference.
Re: long rod vs short rod? [Re: griff70440] #633315
03/08/10 04:30 PM
03/08/10 04:30 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
would i bother changing the rod length, no. would i generally put the longest rod in an engine i could from the start, yes. i know a shorter rod can have positive effects under certain conditions but overall i prefer longer rods. Yunick always preached longer rods and he had a bit of experience.
Re: long rod vs short rod? [Re: griff70440] #633316
03/08/10 04:37 PM
03/08/10 04:37 PM
AndyF Offline
AndyF  Offline
I'd use the longest rod that fits when building the motor but now that you have it together I doubt that I'd go to the expense of changing parts. Not sure you can put much longer rod in there anyway. Maybe a 6.70 Chevy rod will fit in a low deck but that would be about the extent of it. Not like an RB block where you can run a 7.10 rod and still have plenty of room for the rings.
Page 1 of 3 1 2 3
