Re: dana 60????
[Re: whiskeyrunner]
#63324
05/25/08 05:10 PM
05/25/08 05:10 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Truck dana 60s use floating axles. You are better off buy a strange because everything needs to be changed.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: dana 60????
[Re: 70blackfish]
#63326
05/25/08 08:13 PM
05/25/08 08:13 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Dr. Diff priced the changeover components for a B body for me not too long ago for around $500, flanges, bearings and axles. Get the brakes off an 8.75 I believe.
Careful, your character's showing!
Re: dana 60????
[Re: RobX4406]
#63329
05/25/08 09:17 PM
05/25/08 09:17 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
If you are thrifty, you can build a spooled dana out of a truck case for under or right at $1000.
$803 in mine. Housing, gears, spool, bearings seals shims,and Moser axles. Dave
