dana 60???? #63322
05/25/08 05:03 PM
05/25/08 05:03 PM
Freeport, Pa
W
whiskeyrunner Offline OP
W
Freeport, Pa
i have a 1970 duster and im lookin to update my rear. the car will be goin in the low ten second region but will also have nitrous on it to play with on test and tunes. i have an opportunity to buy a truck dana 60. my question is are these rears strong enough for my application or should i go through strange or someone?
thanks,
Matt
Re: dana 60???? [Re: whiskeyrunner] #63323
05/25/08 05:05 PM
05/25/08 05:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it's not going to be a bolt in if thats what you are thinking so once you buy a new set of race axles , possibly a spool and a gear set for what you need you should be good to go .
the housing itself is plenty strong
Re: dana 60???? [Re: whiskeyrunner] #63324
05/25/08 05:10 PM
05/25/08 05:10 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Truck dana 60s use floating axles. You are better off buy a strange because everything needs to be changed.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: dana 60???? [Re: whiskeyrunner] #63325
05/25/08 08:04 PM
05/25/08 08:04 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
once its changed over from a truck axle to a car, its the same as a strange axle strength wise.
Re: dana 60???? [Re: 70blackfish] #63326
05/25/08 08:13 PM
05/25/08 08:13 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Dr. Diff priced the changeover components for a B body for me not too long ago for around $500, flanges, bearings and axles. Get the brakes off an 8.75 I believe.
Careful, your character's showing!
Re: dana 60???? [Re: 70blackfish] #63327
05/25/08 08:15 PM
05/25/08 08:15 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If you are thrifty, you can build a spooled dana out of a truck case for under or right at $1000.
Re: dana 60???? [Re: whiskeyrunner] #63328
05/25/08 09:11 PM
05/25/08 09:11 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
. my question is are these rears strong enough for my application .....
thanks,
Matt
Absolutely.
As said, if you are thrifty, you can build your own cheaply
Re: dana 60???? [Re: RobX4406] #63329
05/25/08 09:17 PM
05/25/08 09:17 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
$803 in mine. Housing, gears, spool, bearings seals shims,and Moser axles. Dave
