Mopar Perf. pinion snubber bent. #633103
03/07/10 06:58 PM
03/07/10 06:58 PM
NE
moparpoolman Offline OP
NE
Hi Guys, Anyone have a pinion snubber bend down toward the u-joint and have the yoke rub on it as it turns?? Is there a better/stronger one (That I Can Purchase Somewhere) that can hold up better?
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633104
03/07/10 07:01 PM
03/07/10 07:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How far do you have it away from the floor of the car when it's siiting on the tires. You shouldn't be bending it if it's set right.
Re: Mopar Perf. pinion snubber bent. [Re: stumpy] #633105
03/07/10 07:06 PM
03/07/10 07:06 PM
NE
NE
When it was new, I set it about 1" from the floor.
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633106
03/07/10 07:13 PM
03/07/10 07:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think a good aftermarket adjustable would be pretty sturdy.
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633107
03/07/10 07:21 PM
03/07/10 07:21 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
If you are hitting-the-floor with a PS that hard .... you have some SEVERE wind-up issues.
BROOM that PS out ..and get a decent set of rear springs !
Re: Mopar Perf. pinion snubber bent. [Re: dOc !] #633108
03/07/10 07:51 PM
03/07/10 07:51 PM
NE
NE
The car is a 4spd, I'm sure that's a factor.
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633109
03/07/10 07:59 PM
03/07/10 07:59 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes. I've bent the orginal brackets before. I make my own as the aftermarket ones are usually to tall with factory springs.
Re: Mopar Perf. pinion snubber bent. [Re: BSB67] #633110
03/07/10 08:12 PM
03/07/10 08:12 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Some guys find good results by ditching the adjustable pinion snubber and rely on adding more spring clamps to the leafs to stiffen them up.
Re: Mopar Perf. pinion snubber bent. [Re: BSB67] #633111
03/07/10 08:13 PM
03/07/10 08:13 PM
NE
NE
I have factory springs in my car and my after market Mopar Performance snubber was to tall also. I cut mine down so 2 hole were left on the top part and bottom part and it gave me the right space that I needed. But I still need to know what I should do now, another one like I had or what else is there that would be stronger???
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633112
03/07/10 08:53 PM
03/07/10 08:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Stronger
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633113
03/07/10 09:02 PM
03/07/10 09:02 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
A stick-shift is a MAJOR factor here .. that is why the people who offer SS springs have specific manual-transmission springs.
If this continues - even with a new PS - you could start spitting-out drive shafts AND breaking tail-housing and maybe even BENDING output shafts.
Re: Mopar Perf. pinion snubber bent. [Re: BSB67] #633114
03/07/10 09:46 PM
03/07/10 09:46 PM
NE
NE
Stronger
That looks stronger. I need one for a Dana60, Where can I get one?
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633115
03/07/10 10:09 PM
03/07/10 10:09 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Stronger
After you get a HD PS .. you are going to start CAVING THE FLOOR IN.
A pinion-snubber is a BAND-AID ...and a waste of money.
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633116
03/07/10 11:53 PM
03/07/10 11:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Just measure up what you have now and check the fit and adjust accordingly.
Re: Mopar Perf. pinion snubber bent. [Re: BSB67] #633117
03/08/10 12:11 AM
03/08/10 12:11 AM
NE
NE
I think you missed the part of my post that says my snubber bent and is rubbing on the yoke of the rear. I can't use the one I have. Thanks anyway
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633118
03/08/10 05:45 AM
03/08/10 05:45 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
1" from the floor also says your rear suspension only has 1" of travel.
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633119
03/08/10 07:13 AM
03/08/10 07:13 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
No I didn't miss that part. You can still get all the dimensions that you need along with a little time under the car. The mounting and the bumper mount are parallel.
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633120
03/08/10 10:11 AM
03/08/10 10:11 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
So is mine and I don't use one. You need a good set of springs, as Doc Fiberglass has suggested. Way too much wind up.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Mopar Perf. pinion snubber bent. [Re: moparpoolman] #633121
03/08/10 11:08 AM
03/08/10 11:08 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I would follow the Chrysler racing engineers advice and run a pinion snubber as well.
Sheldon
Re: Mopar Perf. pinion snubber bent. [Re: 68LAR] #633122
03/09/10 03:10 PM
03/09/10 03:10 PM
NE
NE
After reading all the responses, I'm thinking that I should change my 42yr old springs. My car is a 68GTX so the springs on there now are what was HD then and the pass side has one more leaf than the driver side. What should I buy, Super Stock Springs or the Extra Heavy Duty Leaf springs or something else????? Where should I buy them????
