big block MP steel shim head gaskets, any issues?
#63219
05/25/08 01:56 PM
05/25/08 01:56 PM
RapidRobert
Do these seal OK? & would a thin coat or 2 of alum paint or copper coat help them seal better. Going on a mild 9-10 to 1 streeet engine. Thank you for your time.
Re: big block MP steel shim head gaskets, any issues?
[Re: RapidRobert]
#63220
05/25/08 02:04 PM
05/25/08 02:04 PM
As long as your surfaces are smooth and not too rough they will seal great--some shops go with too much RA and then ya got trouble--I forget what the RA needs to be---most folks spray with Coppercoat or Spray Holomar---if you can feel anything with your fingernail on the surface pattern I would go with a 1009 Felpro or similar
[Re: DaytonaTurbo]
#63222
05/25/08 02:35 PM
05/25/08 02:35 PM
RapidRobert
Alright I'm happy. I just nabbed a set on eGay before consulting with you guys first I will have the surfaces ground smooth & use copper coat. thanks guys.
[Re: RapidRobert]
#63223
05/25/08 04:50 PM
05/25/08 04:50 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use Permatex High Tack on mine.
[Re: 383man]
#63225
05/26/08 01:03 AM
05/26/08 01:03 AM
RapidRobert
alright I will use permatex high tack PS is that the (red) spray? If so I have a can.
