Crane Gold adjustable rocker preload help please? #63200
05/25/08 01:51 PM
05/25/08 01:51 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Quick question on preload for Crane rockers. My cam
(edelbrock) says to adjust rocker arms as follows:
When no 1 cylinder exhaust valve starts to move up,
adjust intake rocker arm to zero clearance between rocker and valve tip. Turn adjusting screw down 1/4 turn more for final adjustment.
They are hydraulic rockers. This seems a little vague and error prone dont you think? So is there a better way, and should the pushrods be snug to tight at TDC or should they both be loose?
Someone with real experience please?
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63201
05/25/08 02:25 PM
05/25/08 02:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
hydraulic lifters use preload...
you turn your adjuster until all the slack is gone in the adjuster, then preload the lifter..as noted 1/4 turn.
you can use edelbrock method of determining went to adjust a valve or you can use the valve lash sequence that mopar has which ever you like...
Tony
70 AARCuda Vitamin C
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63202
05/25/08 06:41 PM
05/25/08 06:41 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
The problem with setting preload on hydraulic lifters is that you can be dealing with already bled-down lifters AND lifters that still have some oil in them.
You'll have to get the feel for it when a lifter is really bled-down, or still has some amount of oil in it which is resisting further travel of the lifter-cup and will start to push open a valve.
Once you get 'the feel' in your fingers you can set the preload practically with your eyes closed.
Re: Crane Gold adjustable rocker preload help please? [Re: BigBlockMopar] #63203
05/25/08 06:45 PM
05/25/08 06:45 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
These sat over night. I was basically verifying they
were set right when I bought it. At TDC on all cylinders I can spin the pushrods. I would guess this is close as it will make sure they are fully closing.
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63204
05/25/08 07:26 PM
05/25/08 07:26 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
you primed the engine's oil pump, right ?
do it while someone turns the crankshaft slowly. the lifters will be filled.
Re: Crane Gold adjustable rocker preload help please? [Re: mark7171] #63205
05/25/08 07:36 PM
05/25/08 07:36 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I was the one turning it slowly.........
I used a dial indicator to find exact TDC and could
lightly spin the pushrods. They were the same of all
cylinders. I drive it last night and turned the crank by hand today as I was finding tdc for all cylinders. Would that be close enough?
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63206
05/25/08 09:50 PM
05/25/08 09:50 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Note, Applies only to individual cylinders:
When Exhaust starts to open, intake lifter is on cam base (completly off the lobe), so you can adjust the intake valve lash.
When Intake closes, adjust exhaust lash (same reason.)
If you can verify TDC of Compression stroke (not overlap), you can adjust both intake and exhaust valves.
The Adjuster screws are 24TPI so one turn = 0.04167"
If you remove the freeplay, you should be at zero pre-load and the inner piston of the lifter should be all the way up to retaining clip.
Adding an additional 1/4 turn should depress the lifter piston 0.01042". This is the spec often used to get maximum performance, but most cam/lifter suppliers spec 0.020" to 0.060" of lifter pre-load. I would use 1/2 turn pre-load or more unless you plan to re-check the valve adjustment ofter engine break-in. Also when running with small amounts of pre-load it is recommended to use the "C"-clip type lifter retainers, not the wire type retainers.
Re: Crane Gold adjustable rocker preload help please? [Re: 451Mopar] #63207
05/26/08 12:18 AM
05/26/08 12:18 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Isnt too much preload worse than not enough?
Verified TDC of compression stroke there is not
rocker free play, should be good to go?
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63208
05/26/08 01:05 AM
05/26/08 01:05 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
too much preload and the valves will not shut.
Tony
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63209
05/26/08 02:54 AM
05/26/08 02:54 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
way too much pre-load and true the valves will not close at all. I think there is over 0.120" travel in the hydraulic piston travel.
Re: Crane Gold adjustable rocker preload help please? [Re: 451Mopar] #63210
05/26/08 09:16 AM
05/26/08 09:16 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
nahh at, +90 +90 on a hydraulic lifter adjustment, is fine. check them after a heat cycle anyways. the oil psi is #60lbs -/+, the pushrod will sink and the valve will close, because the spring pressure will overcome it.
the oil pressure keeps them even. adjustments keep them even.
on a cold HP hyd. cammed engine with lifters that have bled down, on start up it will "lifter clack" until psi builds in the lifter. that is normal after 1/2 " of high performance valve lift.
Re: Crane Gold adjustable rocker preload help please? [Re: mark7171] #63211
05/26/08 10:47 AM
05/26/08 10:47 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
So the question is does it sound like my preload is set ok then?
Re: Crane Gold adjustable rocker preload help please? [Re: mark7171] #63212
05/26/08 10:51 AM
05/26/08 10:51 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
mark, this is the nasty edelbrock cam you were helping with in my hesitation an low rpm post. Lots of overlap on this one. Still pulls 120 cranking pressure if that helps
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63213
05/26/08 12:03 PM
05/26/08 12:03 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
are you affraid you'll coil bind with the performer cam, and bottom out the lifter ? im not. if you had a light twisting effort on the pushrod at addjustment. then went +90, and again +90 more for preload, it will NOT BOTTOM OUT (opening the valve), or FALL OUT at high rpm.
the cam is mild enough should have no geometery problems..
Re: Crane Gold adjustable rocker preload help please? [Re: mark7171] #63214
05/26/08 05:06 PM
05/26/08 05:06 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I dont have any valve or lifter clatter so I would
guess it's ok for now. Mark are you saying the spring pressure will overcome the pump up of the lifters?
Re: Crane Gold adjustable rocker preload help please? [Re: Dart 340] #63215
05/26/08 08:20 PM
05/26/08 08:20 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Make sure that when doing this that the lifter is on the base circle of the cam. Proper preload cannot be accomplished it it is not.
Re: Crane Gold adjustable rocker preload help please? [Re: MoparforLife] #63216
05/26/08 10:51 PM
05/26/08 10:51 PM
If you've run the engine and after sitting all night you can "SPIN" the pushrods at TDC on each valve, you have no preload. Here's how to develop the feel you need to do this right. Bring #1 intake up to TDC and back off the adjustment until you can shake the pushrod up and down. Then, while still moving the pushrod, slowly turn the adjuster until the pushrod "JUST" won't move up and down,then turn the pushrod. This point is zero lash. While you continue to try and turn the pushrod turn the adjuster whatever additional the cam grinder says is appropriate. After doing this a few times you will develop the feel and the proper technique.
Re: Crane Gold adjustable rocker preload help please? #63217
05/27/08 09:33 AM
05/27/08 09:33 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Is this with engine cold or hot? Expansion, lifter pump up etc changes from cold to hot engine.
