Damn... the Trailer is Stuck
#631338
03/05/10 01:26 PM
03/05/10 01:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wanted to pull the car out of the trailer today so I plowed the snow in front of it, there isnt any snow on the south side but in between the shop and the north side of the trailer(where the sun doesnt get to) there is some snow BUT the left side tires are froze in... I'll have to wait till it warms up more today and see if I cane get it to move... BUMMER
Re: Damn... the Trailer is Stuck
[Re: bwdst6]
#631341
03/05/10 02:04 PM
03/05/10 02:04 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Have the same problem. I just about need a D9 Caterpillar to get mine out!
Nowhere near a D9 but I have a D3 here that could probably yank it out
We skid some pretty big logs out of the woods with it I'm sure your trailer you would be no problem
[Re: DemonDust]
#631342
03/05/10 02:11 PM
03/05/10 02:11 PM
MR_P_BODY
I could probably hook my tractor to the truck and maybe pull it out but the wife doesnt like to drive the truck OR the tractor but she's not here, she went over to her sisters place and wont be back till after dark anyways, which then everything would be froze again
[Re: MR_P_BODY]
#631343
03/05/10 02:52 PM
03/05/10 02:52 PM
Posts: 5,080 organ
maximum entropy
organ
prolly rip them wheels off'n yer trailer, prolly. be right careful!
[Re: rebel]
#631345
03/05/10 03:48 PM
03/05/10 03:48 PM
Posts: 3,695 nc
emarine01
nc
[Re: emarine01]
#631347
03/05/10 03:59 PM
03/05/10 03:59 PM
MR_P_BODY
Well I got the trailer out... hooked up my tractor to the truck and pulled the whole thing out till I got the duallies on the pavement.... now I cant get to fire up.... E-85 dont like this cold... I pulled the plugs and they're all wet so I'm going to try cooking them for a bit(I dont have any spare plugs that I can find)... I guess I better give it a drink of regular when I try to fire it again
[Re: emarine01]
#631349
03/05/10 05:05 PM
03/05/10 05:05 PM
Posts: 34,947 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I have same issue but ..its due to wet ground trailer is parked on asphalt but have to swing thru the yard to get out
Too wet, has been since Sept to pull out
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: emarine01]
#631350
03/05/10 05:13 PM
03/05/10 05:13 PM
MR_P_BODY
Hey Mike, A problem with the E fuels, They do not like to sit around with no movement for a bit of time cause the ethanol sucks up water in the air makin it heavier than the fuel and falling to the bottom of the tank <phase seperation> Big problem with gas boats, We have to stir the gas tanks on the boats in the spring before start up other wise you just soak the plugs, seems like there is just something new every year
Yeah I pumped out the tank last fall and put some fresh E-85 in it today but its too cold to fire it, was 35* in the trailer about 40* outside... I didnt have any brake clean to spray it with but I'll get some tomorrow and some reg gas... I'm all out
[Re: DemonDust]
#631352
03/05/10 05:24 PM
03/05/10 05:24 PM
MR_P_BODY
I used E-85 at the ice drags and had no issues. It was 8-29* outside depending on the weekend...
Are you sure its not winter grade.... the cold is why its changed in the winter... it doesnt like to fire, thats why they change it to about E-70
[Re: DemonDust]
#631354
03/05/10 05:45 PM
03/05/10 05:45 PM
MR_P_BODY
It's whatever came out of the pump at the BP. It was probably winter grade. I don't have a tool to check. The car ran great though...
Yeah thats winter grade, most likely its E-70... all I have is summer grade E-85 and it dont like to fire when its cold... I had issues when it was mid 40s
[Re: emarine01]
#631356
03/05/10 06:08 PM
03/05/10 06:08 PM
MR_P_BODY
Mike, how much reg fuel<ratio> do ya mix in to cold fire?
I didnt have any regular... I was hopeing it would fire on the E-85... it didnt so I'll get some regular tomorrow and fire it up... I want to get it in my shop so I can start working on it
[Re: MR_P_BODY]
#631357
03/06/10 03:52 PM
03/06/10 03:52 PM
MR_P_BODY
Well I got the car fired up and in the shop... just had to give it a couple little drinks of regular and it fired right up... now that its in the shop I can get to work on it.... I'm a happy camper now
