Why do i have oil in the combustion chamber? #63108
05/25/08 10:46 AM
05/25/08 10:46 AM
Anonymous OP
Anonymous OP
Need some hemi help here. New 472 hemi that i built. Dual quad stage 5 intake, stage 5 heads, manley valves/seals, je pistons/rings, roller everything, blah, blah, blah. Have had this thing apart twice now because it keeps burning oil. I thought it was the intake manifold gaskets at first, so took it apart, resealed everything and re torqued repeatedly. Did a leak down on each cylinder and they all check out fine, so cant be rings. New felpro head gaskets with copper sealer - no leaks externally - dry as a bone. Start up and with in first 5 mins, light mist of blue smoke. Pull valve cover and plugs and every plug is black with soot and can see oil deposit on piston head - every cylinder. Using manley valves with 5/16 stems (1.88 exhaust, 2.25 intake) and seals. The only thing i didnt do when engine apart was remove valves, but did have the heads pressure checked and they are fine. I cant figure out how oil is getting into the combustion chamber. About the only thing left is the valve guides, but they are new when i built the thing (black manley valve guide seals). This thing is acting like there are no seals on at all. And i cant imagine that the intake manifold gasket is leaking that badly on every cylinder....HELP!!!
Did i screw something up putting on the valve guide seals? Could i have put on a wrong size seal that is too big? Any advice would be appreciated...
Rob
rcola427@aol.com
Re: Why do i have oil in the combustion chamber? #63109
05/25/08 10:57 AM
05/25/08 10:57 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
do you have a pcv valve if so does it have a baffle under it.
Re: Why do i have oil in the combustion chamber? [Re: ademon] #63110
05/25/08 10:59 AM
05/25/08 10:59 AM
Anonymous OP
Anonymous OP
yes and yes...
Re: Why do i have oil in the combustion chamber? #63111
05/25/08 11:31 AM
05/25/08 11:31 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Do you have the PC seals or the black umbrella types, i would rather have the pc's
Re: Why do i have oil in the combustion chamber? [Re: ademon] #63112
05/25/08 12:00 PM
05/25/08 12:00 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Leaks at intake, intake bolts , inner studs or spark plug tubes??
I don't think any of those would oil up a motor THAT fast however.
Within 5 minutes everything is oiled up?? Just idling??
Re: Why do i have oil in the combustion chamber? [Re: SSAAHemiFan] #63113
05/25/08 12:26 PM
05/25/08 12:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
did you put a thread sealer on the studs that go into the intake ports ?
Re: Why do i have oil in the combustion chamber? [Re: JohnRR] #63114
05/26/08 10:12 AM
05/26/08 10:12 AM
Anonymous OP
Anonymous OP
yes on thread sealer to the studs going into the intake ports, black umbrella type seals on the valve guides, i re-sealed the intake manifold gaskets using hi tack around the outside and black permatex for the rest and have retorqued it 3 times now. Wondered about the spark plug tubes but the seals are in place and what would you do if it was leaking? Thread sealer on the spark plugs? That would make me a little nervous...
Re: Why do i have oil in the combustion chamber? #63115
05/26/08 10:20 AM
05/26/08 10:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i don't think uou have a leak thru the plugs , you did remove the gasket off the bottom of the plug i assume , thats something i didn't know about .
the intake can be very tricky to have seal from things i have read here , mines not together and running yet so i'm sure i'll be going thru this same stuff
Re: Why do i have oil in the combustion chamber? [Re: JohnRR] #63116
05/26/08 10:36 AM
05/26/08 10:36 AM
Anonymous OP
Anonymous OP
No, i did not know about removing the gasket - you're referring to the washer right? If that is the case, if that is it, ill be relieve and feeling like an idiot all at once. Especially since i built the entire thing... I just cant see how it can be getting past brand new valve guides or intake to such a degree...and its consistent on all 8 cyls...i will try it - thanks...
Re: Why do i have oil in the combustion chamber? #63117
05/26/08 10:48 AM
05/26/08 10:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes the washer that slips over plug threads , the spark plug tube does acts as the same thing ... i guess ???
Re: Why do i have oil in the combustion chamber? #63118
05/26/08 11:13 AM
05/26/08 11:13 AM
N
NITROUSN Offline
NITROUSN  Offline
N
These seal the tubes up and are supposed to work real well.
http://stores.casselent.com/Detail.bok?no=46
Re: Why do i have oil in the combustion chamber? [Re: NITROUSN] #63119
05/27/08 02:16 PM
05/27/08 02:16 PM
Anonymous OP
Anonymous OP
thanks - these are placed in the existing hole for the tube?
Re: Why do i have oil in the combustion chamber? #63120
05/27/08 03:34 PM
05/27/08 03:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes , then you put the tube back in .
